DIY change engine air filter?
Old May 25, 2008 | 12:49 PM
stathis's Avatar
How do you change the engine's air filter? I presume unscrew the engine cover? Any photos out there?
I already got the cabin air filter, thanks to the info posted on this forum.
Thanks.
Stathis
Old May 25, 2008 | 01:32 PM
kabota's Avatar
1. Open hood.
2. Loosen the bolts on the air filter box.
3. Replace air filter.
4. Tighten bolts on the air filter.
5. Close hood.
Old May 25, 2008 | 07:32 PM
The Dougler's Avatar
Unofficial Goat
this is a stock photo, but with my drawings you should get the point.
The box in the corner circled in red is the air box, there's 4 bolts, 1 in each corner, should be a 8mm socket to get them out, you'll probably need an extension to get the back right one out.
Old May 25, 2008 | 07:57 PM
mau108's Avatar
uncrew but the screws don't come out, they just loosen up and then remove the cover.
Old May 26, 2008 | 09:57 PM
stathis's Avatar
that's perfect, thank you.
Abe_Froman
Sep 16, 2015 01:27 PM
Aleax
Sep 11, 2015 11:31 AM
Aleax
Sep 9, 2015 08:04 PM
sputik
Sep 7, 2015 01:40 PM
bymotion
Aug 31, 2015 05:00 PM
