DIY: Cabin Air Filter Replacement
To add to this thread. If you accidentally pull to hard and the shock comes off the glove box, first instincts are to push it on to the white clip fro behind into the eye of the shock. That doesn't work. it actually slides into the white clip itself. I tried to google this and no answers. Thought i would save someone the headache if they did the same thing.
Acura cabin air filter!
Hello
You can find all steps to change acura cabin air filter by yourself:
For 1998-2003 Acura CL - http://filterlocation.com/acura-cl-air-conditioning-filter-location/
For 2001-2005 Acura EL http://filterlocation.com/acura-el-a...lter-location/
For 2002-2006 Acura RSX http://filterlocation.com/acura-rsx-cabin-air-filter-location/
For 2007-20010 Acura CSX http://filterlocation.com/acura-rsx-cabin-air-filter-location/ and more others.
Check here: http://filterlocation.com/category/a...lter-location/
Thanks!
Thanks!
I have the 2013 RDX. This was an easy job. No need to remove the glove box door for the 2013 model. Simply remove the removable shelf inside the glove box. The compartment for the filter is in the back. Remove the outer flap door and the inner filter door. Slide the old filter out, new filter in. Replace all doors. Done!
I am really interested in doing this, but the pics are gone, is there somewhere that has the DIY with pics?
Edited:
LOL, I stopped reading when the pics didn't show up. Didn't see the video-gonna watch it.
Edited:
Going from memory...empty glove box, open and pull the tabs at the back to allow it to drop completely. Air filter tray should be right in front of you, held in place by a few plastic tabs/clips. Unlatch them, pull out tray, swap filter (pay attention to air flow arrows!), and replace. Video should help, but honestly you can fumble your way around and do it. There are no tools required, so very little chance of doing any damage with your bare hands.
Honestly this is the easiest thing to do in this car, even easier than replacing the engine air filter. On top of easy filter location, it also has a filter tray. My previous few cars had it in the same location, but you had to wiggle the filter into the slot. This one, just slid the tray out, drop in the new filter, and put the tray back.
Use the video on this post - it'll show you everything you need.
https://acurazine.com/forums/1g-rdx-.../#post14032855
andreythedon
Jan 21, 2017 09:58 PM
CheeseyPoofs McNut
Oct 2, 2016 11:37 AM
