Dim Interior light
Old Mar 12, 2011 | 11:54 AM
Tim Staken's Avatar
Dim Interior light
Hey Guys,
I have a 2007 RDX that I really like. This morning my wife wanted to start the car and the battery was dead. I noticed after i had boosted it that the interior lights were dim even after the car would start and was fully charged.
I'm assuming that is what is slowly draining that batt... was wondering if there was anyone else that had a similar problem and if so what can i do to fix it.
Old Mar 13, 2011 | 05:35 PM
737 Jock's Avatar
haole kama'a-ina
If your 07 has the original battery, it's most likely time for a new one. You can have Advance Auto check your charging system for free to be sure. Their test unit will identify the faulty component.
OEM batteries are low on power (cold cranking amps). Get one with higher CCA. The battery size is 35 (or 35N at WalMart).
If the new battery doesn't cure the interior lights problem, you might have a problem with a control module.
Old May 29, 2013 | 09:19 PM
rossmo's Avatar
Wasn't there a known issue with an open circuit on the 2007 RDX? I ask because on mine (just purchased) it seems to take a 2-3 seconds to turn over and start and I had a dead battery issue already. I had a mechanic take a look and he says te battery/alternator look good.
thoughts?
Feb 25, 2020 09:57 AM
oyayjoe
Jan 1, 2019 10:17 PM
handsom-hustla
Nov 13, 2015 05:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
oyayjoe
Sep 12, 2015 04:40 PM
