235/50/18's on stock RDX 18" wheels?
Hi, I'm about to replace my original stock RDX tires, and I was wondering if anyone has tried to do a plus 0, and replace the OEM size 235/55/18's with 235/50/18's. I did some searching online and I haven't found an answer. Thanks!
Carbon Bronze Pearl 2008
235/50/18 27.25 you will lose almost an inch of ground clearance
235/55/18 28.18 STOCK RDX
245/50/18 27.65 Option 1 <--- Best Choice
255/50/18 28.04 Option 2
Obviously, you are looking for a "sportier" feel and look to your RDX with the lower profile tire option. In cases like this, unless you live in a dry state, no significant cold precipitation or ice, you are better off with the current stock set up and with good all seasons.
On the contrary, if you live in a place with little snow/ice occurrences, and want the sportiness, I still would suggest going with a Plus 1 option, 19" rim/tire, lower profile and summer tires on it, and keep your stock rims/tires for the occasional need for it in the Fall and winter.
If you want to rework the tires, you might as well do it right and save yourself any trouble down the road.
Thanks BigHatch - You're right. I overlooked that. If diggerdave still wants to keep the stock rims then he should definitely go for the 245/50/18. The height difference would only be about 0.265 or basically a quarter of an inch loss in height.
I wish I could have convinced myself to do the 19" rims with the tires, but I couldn't rationalize the price. I went with some 245/50R18 Yoko all seasons from Tire Rack. I also ordered a set of ceramic front pads to hopefully take care of some grinding.
What Yoko's did you choose exactly? What was your major deciding factor on them?
I haven't thrown them on yet, but I'll update on their performance once I get them installed.
The Yoko's are working out great. The handling is about the same as stock tires; maybe a little better in the turns. They're better in the snow than my old stocks even though they are a little wider. My speedo is registering speed over by 1mph if that (gauging it by comparing it to the speed on my Garmin and who knows how accurate those are). If anyone is considering going to a wider tire I'd recommend them.
rockyboy
01-25-2016 06:00 PM
mtl_ilx
09-03-2015 09:58 PM
