2011 rdx license plate lights
CSmoney28
It's very easy you can get nice led lights on eBay search for 194 LED I like the seller J87. Make sure to get the smallest bulbs in this case the hole is very tight. You will need two bulbs for this job and a flat head screw driver that's all. Open the tail gate you will see a long panel with two indents one on each side that's where you pop it off with the flat head. Then you will squeeze each side of the plastic clips x2 done.
