Voice Prompt for Navigation only
Old Sep 29, 2010 | 12:44 PM
duffdachinman's Avatar
9th Gear
Hi all. I was wondering if you know if I can turn off voice prompt everything on the navigation screen with exception to the actual Navagation instrucitons. I find it highly annoying when i'm adjusting audio options, basic setup on the screen and have the nav voice talk while scrolling through the menu. Right now I turned the Voice Prompt volume to off, but when using the Navigation, the voice prompts aren't there anymore.
Thanks for your replies!
9th Gear
I drive a 2007 RDX Tech. Thanks.
Old Oct 1, 2010 | 03:35 PM
phoward_15's Avatar
You have to go into the setup part of the system and there is a function to turn it off. I have mine set up so only the Nav talks back. I think the option is called "Guided Prompts" or something like that. Just play around with it and you'll find it. When I get into my car later this evening I'll see if I can find it.
dirleton
Aug 6, 2024 08:19 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
TLguy42
Sep 26, 2015 11:27 AM
