Upgrade to factory xm radio
New to the forum. Just purchased a 2007 Acura RDX with tech package, but I don't have the stereo with the xm radio. Is it possible to purchase a stereo off line with the xm radio and install it ? Thank you in advance
I’m sure, you could do the Bluetooth steaming modification and stream from your phone to the vehicle.
Also, you could probably mount the aftermarket XM radio in your vehicle.
Third, you could hook up your phone to the aux or usb socket if you have one and put it on in your phone.
If you don't have the xm radio button, most likely you will not have the port on the back of the radio to add that cable. If you do have the port you won't have the button to change it to xm or to the iPod cable.
97AcuraCL
Apr 20, 2012 03:53 PM
mm5300
Oct 21, 2010 04:43 PM
FTM-1
26
Jun 27, 2002 04:37 PM
