Sunlight Sensor and Nav Screen Brightness
From the previous thread:
It does say that (Nav Manual p 105) but it doesn't seem to be working:
The same page also states that use of the Display Mode (day/night) switch, just once, overrides all other functions until the ignition is cycled again. But flar, I doubt if you used the Display Mode switch before exiting the dark parking garage.
So I checked the Helms Service Manual. (p 23-125):
No mention of screen brightness, and the schematic backs this up, showing the sunlight sensor signal feeding directly into the Climate Control unit along with a solar angle signal from the Nav. But no sunlight signal to the Nav unit or Display Screen.
If this is correct (and the Nav Manual is wrong) then I'm guessing that they decided there were too many overrides. Both the Display Mode switch and the Dash Illumination knob override the headlight signal. Throw in the sunlight sensor and you'd have people ready to punch the screen.
Originally Posted by kirkacanada
In the navigation package user's manual, the priority settings clearly state the sunlight sensor is supposed to detect sunlight and adjust the NAV display to DAY mode...even if the headlights are on, and the center console brightness display is not set to MAX. I have a technician at our local Acura dealership looking into it.
Originally Posted by flar
Unfortunately, in my testing over the past 2 days this doesn't appear to function at all. Today I even went about 3 minutes in bright sunlight directly overhead with no clouds or shadows and the display stayed on the night settings the entire time.
The navigation system uses the sun's angle, along with the sunlight sensor to control the driver/passenger A/C airflow.
Originally Posted by neo1738
nav does not react to sunlight sensor, only headlights or the override button on bottom left.
I was hoping someone here could help me, please. My nav screen does not automatically switch to the Night setting when it's dark out or when I turn my lights on. I have it set to be the off white for day and gray for night, but it only changes if I manually hit the button. Is there something I am missing with regard to a setting? Any help is appreciated. Thanks!
1. Make sure the colour setting is set (as you mentioned earlier..off white for day and gray for night).
2. Turn on your headlights.
3. There's a little knob sticking out of your instrument panel. Give that a turn counter-clockwise. As long as the setting is not full, the nav screen should turn gray.
Hope that helps.
Thank you so much number84! It worked perfectly. That had been bugging me since I got the car and the manual is so confusing.
i played around with that because i was really getting annoyed that i couldn't tell if my headlights were on. i drove a few times at night without any headlights on...not very safe, obviously!!! now i can easily remember since the nav screen is a big enough reminder vs. the little green headlight icon in the instrument panel.
navtool.com
31
11-16-2015 08:30 PM
