Navigation "Disc Read Error"
Old Jul 7, 2015 | 06:02 PM
Jdrum1's Avatar
While on vacation, my nav system crapped out with the "disc read error" message.
Of course, I was in a city (Denver) when it happened......
Pulled over, opened the DVD cover, and it smelled hot. Ejected and reinserted the disc to no avail.
When you turn on the car, the nav works fine for about 5 minutes, then the error message appears.
For the heck of it, I blew the cubby and DVD drive out with some compressed air. No change.
I just happened to get a new disc a couple weeks ago, but since the system worked fine from Texas to Denver, I don't think it's related.
It seems to be a not at all uncommon Acura issue. From what I've read, I can send the unit to Apline for repair (around $350). I don't like that idea.
I found a cleaning and lube DIY for a different model Acura (unit looks the same). I figure that's my next step.
If that doesn't work, how about used off eBay (especially if it's guaranteed to work)?
Thoughts? Ideas? Donations to my navigation system fund?
On a side note, the RDX is a BEAST in the mountains! OMG.......fun.
Old Jul 10, 2015 | 09:05 AM
Jdrum1's Avatar
As a reference for anybody else that has this issue;
I'm thinking the fan in the DVD drive may have died. I'm going to pull the drive and check. If so, maybe I can find a close fit.
If it's the drive itself, I've found a lengthy post where people had luck with replacing the inner components of the drive (with cheap online replacement parts). This seems to be run around $40-$50. I'll give the unit a good cleaning before trying this.
I'll be sure to report back.
Old Jul 10, 2015 | 09:24 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Subscribed.
Just based on what you have described so far the failed fan sounds like a good diagnosis. You said it works for about 5 minutes ( time enough to heat up???) and when you first opened it up "it smelled hot." Not sure smelling hot is a good description, but I get what you are trying to say.
Old Jul 10, 2015 | 09:35 AM
Jdrum1's Avatar
I didn't want to that it smelled like something was burning, but I'm sure you know that hot electronics smell I'm referring to.
Now to figure out how to remove the unit.......
Old Jul 10, 2015 | 09:46 AM
NBP04TL4ME's Avatar
This may be helpful - https://acurazine.com/forums/audio-b...errors-873489/ The first part talks about drive removal from the trunk.
Old Jul 10, 2015 | 10:35 AM
Tomtwtwtw's Avatar
The main difference is that the DVD drive on the RDX is actually in the front of the car, accessible from near the passenger side below the cupholders. At least, to replace the disk that's where you go. Not sure if that panel gives you enough access to remove the whole drive or if you have to start pulling apart the center console. Once accessible though, the procedure should be the same.
Old Jul 10, 2015 | 10:43 AM
NBP04TL4ME's Avatar
^^^^ My bad.
Old Jul 10, 2015 | 10:55 AM
Tomtwtwtw's Avatar
^^^^ My bad.
Hey, still useful info! The drive itself is probably the same for all Acuras that use that particular disc.
Old Jul 10, 2015 | 01:16 PM
NBP04TL4ME's Avatar
It is likely the same or very similar, but I can't believe I missed the fact the OP posted this in the 1G RDX forum, commented on how the RDX handles and mentions the RDX in his signature -
Old Jul 10, 2015 | 01:23 PM
Jdrum1's Avatar
Lol!
I looked at a diagram, and I think I can pull the unit without having to disassemble the console
The tread you linked is where I've been reading about possible fixes.
Old Jul 12, 2015 | 01:25 PM
Jdrum1's Avatar
For reference, the drive model # is DV36M110.
Looks like it can be purchased from AliExpress from around $40.
Have yet determine if my fan is working. There isn't enough slack in the cables to pull the unit out of its cubby while powered up......
Just finished cleaning the laser, so we'll see what happens.
Old Jul 12, 2015 | 01:35 PM
Jdrum1's Avatar
Also, I think I'm going to leave the cover off to help dissipate heat. I know this puts it at some risk to dirt, but the space the drive is in is super clean and well sealed.
Old Jul 12, 2015 | 02:08 PM
Jdrum1's Avatar
Just reinstalled with the cover off. Worked upon startup (be sure to have your Nav code handy) with no issues.
Used mirror to see if the fan was spinning, and it wasn't. That said, the unit may have not gotten up to temp for it to kick on.......
I let it run for 10-15 minutes, and no problems. I'll find out later today if it's really fixed.
If it works, I won't know it it's due to cleaning or to heat dissipation (since the cover is off). I'm a scientist; I don't like not knowing what to attribute my results to!
If I get the error again, I'll use the mirror again to check the fan while I'm getting the error. If it's the fan, somebody linked a replacement in the long TL thread.
I'm still leaning towards something heat related given the way it smelled when it first crapped out in Denver.
Old Jul 12, 2015 | 02:10 PM
NBP04TL4ME's Avatar
Interesting results so far. Keep us posted!
Old Jul 12, 2015 | 02:14 PM
Jdrum1's Avatar
I absolutely will.
It's a frustrating problem, and I'm more than happy to park this information here for anybody who needs it in the future.
Old Jul 13, 2015 | 12:12 PM
Tomtwtwtw's Avatar
By fan are you referring to a little fan in the console to keep the drive cool? If so I highly doubt it's temp-controlled. It should function like a basic computer case fan and just spin. Hopefully your continues to work well!
Old Jul 13, 2015 | 01:00 PM
Jdrum1's Avatar
That's the one. It's spinning, but unfortunately, I'm still getting the error.
With the cover off, and the panel open, the drive is EXTREMELY loud. Lots of odd clicking noises.
I did just return from some errands, and on the trip back home, no clicking noises and no error message. I think something in the drive is failing.
Guess I'll turn to AliExpress for a replacement.
Old Jul 13, 2015 | 01:16 PM
Jdrum1's Avatar
Drive ordered for a total of $52.
Old Jul 13, 2015 | 01:50 PM
Tomtwtwtw's Avatar
Good luck!
Old Jul 16, 2015 | 08:28 AM
Jdrum1's Avatar
Of course it's worked just fine since I ordered a replacement!
Old Jul 16, 2015 | 08:39 AM
NBP04TL4ME's Avatar
Isn't that usually the way? Just keep in mind Murphy is always lurking............
Old Jul 29, 2015 | 07:05 PM
Jdrum1's Avatar
Got the replacement. It looks EXACTLY like what was in it (other than different numbers printed on it).
The unit did not work at first; the worm gear wasn't making contact with the laser mechanism, so the laser wouldn't move. Messing with it a bit seemed to fix it, and it's been fine for a few days.
While changing the units out, I noticed that the ribbon cable clams on the DVD mechanism weren't tight (ribbon cable was loosely in place). I don't think this caused my problem, but it's worth checking for anybody with issues reading this.
I'll be sure to post any updates.
Old Jul 24, 2016 | 11:13 AM
Jdrum1's Avatar
It's almost exactly a year, and the drive is still working great. Absolutely no issues.
Old Aug 25, 2016 | 06:21 PM
chanoh's Avatar
3rd Gear
Jdrum1, Thanks for the update.
I got same issue and need to replace the DVD drive. How did you do that? Is there any manual?
Old Aug 26, 2016 | 10:20 AM
Jdrum1's Avatar
Look up above; there's a link to a thread on the TL forum that will show you how to do it.
Old Aug 26, 2016 | 02:03 PM
chanoh's Avatar
3rd Gear
Found this, but it's dated after your post.
https://acurazine.com/forums/3g-tl-a.../#post15708202
Do you think it's right procedure?
Old Aug 26, 2016 | 08:57 PM
Jdrum1's Avatar
That's the thread I was talking about. Are you referring to a specific post on the thread?
That thread has instructions for cleaning the unit (our is in a different location).
Old Aug 27, 2016 | 01:34 AM
chanoh's Avatar
3rd Gear
Yes, the link is saying about how to remove the drive from RDX. I'm wondering how easy or hard to do that.
Old Aug 27, 2016 | 06:49 AM
Jdrum1's Avatar
I'm guessing you are referring to post #357 in that thread. That's how you remove the nav unit.
You'll need long extensions to reach the bolts that hold the unit down (one in particular is way back there).
From there, I'd follow the original posts directions on how to clean the unit. Try that first. If that doesn't work, try ordering a new drive from AliExpress.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
