Easy Valentine one hardwire
A number of threads are out there on hardwiring the V1 into the rearview mirror, yet no one ever answered the most important question, what wires to use. Well using the three wire harness that connects to the rearview mirror, the dark navy wire is the "+" and black is the "-". Go to http://www.stealthcords.com/shop/home.php?cat=280 and they have the easiest, fastest way to hook it up. It gives you the telephone connector on the detector side and cable with two long metal pins labeled +/- that you simply push into the back of the wiring harness and you are done. Nothing could be simpler.
Hey that is good to know I just bought one with the concealed adapter 2 weeks ago and was also wondering how to connect them .
Easiest way to hardwire a V1 is with the stealth cord:
https://acurazine.com/forums/showthr...e+stealth+cord |
Originally Posted by schen72
(Post 10594946)
Sorry, I think I read your post too fast. I guess we're all in agreement the stealth cord is the way to go.
i posted pictures of the stealth cord install months ago, somewhere in electronics section
https://acurazine.com/forums/1g-rdx-audio-bluetooth-electronics-navigation-159/v1-hard-wire-into-mirror-692180/ |
Originally Posted by neo1738
(Post 10613715)
https://acurazine.com/forums/showthread.php?t=692180 |
there is a blue and purple wire on the rdx, not navy and black, blue is + purple ground, however i found that using the ground on the mirror, when i shifted from park it cycled the power (weird i know) so i put it in the prong between the two and worked fine. again check the pictures i posted (and thank you for the referal to stealth cords!)
I was not combining the colors
Navy Blue is Positive Black is negative If you have different colors then they might have changed with model years, mine is an '07. |
so i went out to check why my pictures didnt agree with your statement, and realized the color on my picture was wrong, you are in fact right and i apologize, secondly for some reason the black wire dint show in my picture, only the purple. gtrrdx is right, score 1 for the good guys
No worries, glad we are all square now.
