07 Acura RDX Tech Radio Locked
Old 01-24-2010, 10:27 PM
L25
L25's Avatar
My battery died, was jump started and now my radio is locked. "Enter Code" is displayed on the time and temperature screen on the upper dashboard, not on the navigation screen. I can not use the present buttons near the CD player to enter in my code because it has a zero in it. Do any of the preset buttons act as the number "zero?" If anyone can help me figure this out without a trip to the dealership, that would be great! Thanks!
Old 02-26-2010, 09:47 AM
7th Gear
esax76's Avatar
I'll double check my manual, but I had the same issue a while ago... When I tried to turn on the audio, the NAV screen prompted me to enter the code. I didn't have (to my knowledge) the "enter code" displayed in the dash. What does your NAV screen display when you try to select audio or map?
Old 02-26-2010, 10:01 AM
7th Gear
esax76's Avatar
This is all I could find in the manual and it's not too helpful:
If your vehicle’s battery is disconnected
or goes dead, or the radio
fuse is removed, the audio system
will disable itself. If this happens,
you will see ‘‘ ’’ on the center
or upper display (depending on
models) the next time you turn on
the system. Use the preset bars or
buttons (depending on models) to
enter the five-digit code. The code is
located on the radio code card
included in your owner’s manual kit.
When it is entered correctly, the
radio will start playing.
If you make a mistake entering the
code, do not start over; complete the
five-digit sequence, then enter the
correct code. You have 10 tries to
enter the correct code. If you are
unsuccessful in 10 attempts, you
must then leave the system on for 1
hour before trying again.
Old 03-19-2010, 08:26 PM
3rd Gear
BCocoPop's Avatar
I believe there's should be 2 codes on the white code card that came with your car manual pack. One is the radio code, the other is the Navi code.
If it prompt you to enter code in the navi screen, you need to enter the Navi code.
If it say, Enter Code in the center top where the time and temperature LCD screen is. That's the Radio code.
Now I have a problem is with the Radio code. I've enter it and it still didn't work. Trying to figure out how to remove the antenna from HU and enter code like other peeps say. Any of you have an idea on how to remove the side panel on HU?
Old 03-19-2010, 10:23 PM
dkswim's Avatar
the numbers should also be in the maintnance record where they have all the predelivery checklist.
Old 06-17-2018, 02:25 PM
Jaimie Kaiser's Avatar
hi did u figure out which button is zero.
rseb4agze
05-03-2016 07:41 AM
1lowtc
1G RDX (2007-2012)
15
11-19-2015 10:52 AM
handsom-hustla
11-13-2015 05:04 PM
d.lim
09-15-2015 08:54 PM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: 07 Acura RDX Tech Radio Locked
