Warranty Work on RDX
I am going to be taking my 2007 RDX to have the window wiper motor swapped out due to an Acura Service Bulletin. However, this will cost me $100 deductable (extended warranty coverage). I wanted to see what else I can tell the dealer to check out that may be covered under my warranty; that way I can get more work done/checked out besides just the window wiper motor for the $100. Any suggestions?
The wiper doesn't run as set on the switch. Like if I have it on the slow setting, it'll sometimes go fast or jolt. There was a TSB for it to be replaced for certain 2007 RDXs.
3rd Gear
I had to take my '07 RDX into the dealer (under warranty) in January this year to have my wiper motor repaired. Back then I Googled the issue and a lot of complaints came up about incorrect wiper speeds, wipers not shutting off properly, etc.
Since then, I've found this article which states the wipers are a known problem, along with two other issues:
- stereo amp doesn't always properly shut-off, drains the battery
- tire pressure display inaccuracies
http://consumerguideauto.howstuffwor...cura-rdx-2.htm
Hope this helps!
Hope this helps!
MMike - from what i know, i don't think that's a tsb. it has happened to me too, not sure what it is though.
thanks for the feedback. i just got my car back with the motor replaced. hopefully this solves the issue. also got a nice ZDX as a loaner. =)
TLDude876
12-28-2016 03:18 PM
rockyboy
01-25-2016 06:00 PM
