Unconventional RDX Build
Old 01-04-2020, 07:25 AM
  #121
tomiek's Avatar
Originally Posted by kevin2m4
I took apart another key (used) for the buttons. I think it was an mdx key. You do have to swap just the buttons not the circuit else the car won't unlock or start.
Ebay has them cheap
Good idea! Thanks for advice.
Old 01-07-2020, 03:15 PM
  #122
CSmoney28
CSmoney28's Avatar
Great idea with the key!!! How did you do the engine block heater install???
Old 01-11-2020, 09:57 AM
  #123
kevin2m4's Avatar
I didn't do the block heater myself, but the battery and tray had to come out, and then the freeze plug was a big bolt.
I got the block heater for 90$ and paid 100$ to have it put in.
Mobil 1 oil was on sale so I got some and did an oil change early because the oil in this RDX was super black, so I did the oil change early. I usually get the 1$ oil filters from Rockauto but decided to try the K&N.
Old 01-11-2020, 09:59 AM
  #124
kevin2m4's Avatar
As described
Old 01-11-2020, 10:02 AM
  #125
kevin2m4's Avatar
I am also doing a science experiment.
Midnight Mystery (01-11-2020)
Old 01-11-2020, 10:05 AM
  #126
Null and proud of it
Midnight Mystery's Avatar
I like your science experiment!!! Are you testing ceramics?
Old 01-12-2020, 04:30 PM
  #127
CSmoney28
CSmoney28's Avatar
Let me know how the k&n filter is when you change your oil, I was thinking about making the switch...
Old 01-13-2020, 01:59 PM
  #128
kevin2m4's Avatar
I am. Would like to know if it keeps the car cleaner.
So far it keeps it dryer.
Camera set to night shows the drops better
Old 01-14-2020, 11:26 AM
  #129
kevin2m4's Avatar
My RDX's alarm started going off last night a few times at dinner. I thought i left it unlocked to stop that.
Woke up and the car was dead.
I believe this is the culprit. (photo from google of used hood switch)
I am going to cut the wire harness in hopefully the laziest easiest way, without removing anything.
Old 01-14-2020, 11:28 AM
  #130
kevin2m4's Avatar
view from the top, cant see the wire here.
view from the bottom... cant see the wire here
Old 01-14-2020, 11:30 AM
  #131
kevin2m4's Avatar
Remove 3 push clips and wiggle that shroud around the hood release handle over to the left.
there you are
snip
Old 01-14-2020, 11:44 AM
  #132
kevin2m4's Avatar
*only 3 push clips because 3 were missing
Old 01-14-2020, 01:14 PM
  #133
kevin2m4's Avatar
Alarm went off again shortly after.
Lets look at the trunk latch alarm switch.
The wire that plugs into the white cover is the power for the release. The other one is for the alarm.
The wire harness for the alarm was pretty wiggly. Unplugged it with a flat screwdriver.
Old 01-14-2020, 11:35 PM
  #134
CSmoney28
CSmoney28's Avatar
It’s weird because my truck and hood latch both act up when it’s cold. Then my car won’t start because it says on my alarm application that the hood or trunk is open...
Old 01-15-2020, 12:13 PM
  #135
kevin2m4's Avatar
This seems to have solved my problem.
CSmoney28 (01-16-2020)
Old 02-09-2020, 03:59 PM
  #136
kevin2m4's Avatar
Ruh oh
Old 02-09-2020, 04:26 PM
  #137
kevin2m4's Avatar
My shawd, TCS and vsa light came on today. Rdx was locked into 2wd. Scanned the vsa and shawd only and got those 2 codes.
Cleared and will drive some more to see if it comes back.
Will scan all if it does. Hope it's not the yaw gyroscope that sensor is expensive.
Old 02-09-2020, 04:30 PM
  #138
kevin2m4's Avatar
Old 02-09-2020, 07:57 PM
  #139
Altair's Avatar
Ruh oh
so you are THE ONE that finally exceeded the limit of RDX's acceleration !
check out kijiji, Toronto area has a few ongoing part outs, some will mail out if need be.
Replacement details would be awesome...
cheers
Old 02-11-2020, 11:34 AM
  #140
kevin2m4's Avatar
cheers
Well I have been trying. Testing the stability assist in reverse is totally normal.
That is a very good idea and I will go the kijiji route if it comes on again.
So far so good after clearing it.
Old 03-17-2020, 01:18 PM
  #141
kevin2m4's Avatar
My fan mode light went out the other day. It's more annoying than I thought it would be. The shawd light etc did not come back on which is good. However my check engine light for o2 sensor is on even with the extender sleeve the Russian exhaust shop provided. Sometimes it goes out on its own but for the most part it's on. Also my ghetto rig of tailgate switch stopped working. The harness connector is green with salt corrosion. I ordered another used tailgate switch but may go another route.
Old 03-17-2020, 01:20 PM
  #142
kevin2m4's Avatar
Old 03-17-2020, 02:21 PM
  #143
kevin2m4's Avatar
Popped out the silver peices. Really easy if you don't care about scratching them like me.
2 screws
Here is where the bulbs sit
The culprit. I don't have one of these.. ...
But you know what else I don't care about? This light.
Yoink
Old 03-17-2020, 02:35 PM
  #144
kevin2m4's Avatar
So I swapped this bulb for the other one and ripped off the blue rubber coating on the bulb.
It works.
Funny thing it's the bulb for the picture of the guy in the airbag indicator. The OFF still lights up.
Old 03-18-2020, 12:51 AM
  #145
kevin2m4's Avatar
Much better
josiahmgillespie (01-30-2021)
Old 03-18-2020, 12:54 AM
  #146
kevin2m4's Avatar
Rust progress.
This is mostly one winter
Old 03-19-2020, 11:58 AM
  #147
kevin2m4's Avatar
New used trunk switch came today
Big difference no salt makes
Old 03-25-2020, 01:18 PM
  #148
corduroy's Avatar
How long did it take you to put that leather cover on?
Old 03-25-2020, 04:48 PM
  #149
kevin2m4's Avatar
Probably an hour and a half
I used a hair dryer to stretch the leather and spray glue to stick it. I wish there was more material at the tips but it looks a lot better than the ripped one and it was cheap.
Old 06-07-2020, 10:56 PM
  #150
kevin2m4's Avatar
Water still beading on the ceramic coated area
Midnight Mystery (06-08-2020)
Old 06-08-2020, 01:51 AM
  #151
CSmoney28
CSmoney28's Avatar
Good job 👍🏻, very interested about switching the dash bulbs out
Old 09-09-2020, 01:18 PM
  #152
kevin2m4's Avatar
Oil change time. Exactly 6000kms it asked for an A service. I am leaving the k&n oil filter on and using the cheapest oil Canadian tire had. It is the wrong oil 5w20 and is not HTO-06.
Old 09-09-2020, 01:20 PM
  #153
kevin2m4's Avatar
It was on sale
Boostlee77 (09-09-2020)
Old 09-12-2020, 01:15 AM
  #154
CSmoney28
CSmoney28's Avatar
The following 2 users liked this post by CSmoney28:
josiahmgillespie (01-30-2021), kevin2m4 (09-12-2020)
Old 10-04-2020, 08:04 AM
  #155
TheCanadian's Avatar
I had the same issue with my hood switch. I did it the long way and removed the front bumper and disassembled everything to unplug it
Old 10-05-2020, 08:26 AM
  #156
ChetnLisa's Avatar
Now, can you fix mine???
Amazing post. I'm new to this forum so thank you for the opportunity to participate. I too have a 2007 RDX Turbo (2.3L K23A1) with 110K on the ODO. It was my girlfriend's car and (no sexism her I promise ;-)) needless to say she "changed the oil every 3K (waste of money at this interval but better than not) and that about it. I did the air filters for her and kept the lights on ha ha. I've got my own cars to fiddle with so I never had much pull when the dealer "suggested" maintenance such as a transmission flush, spark plugs, brake fluid (lots of moisture in the lines in FL), etc. My luck or misery depending on your perspective that she "gave" it to me for $4k. It's a tight little machine (the car I mean) and I've been playing around with it (still talking about the car although it could go either way) for the last few months. It's a mess. Leaks oil (replace the valve cover seal, oil filter housing o-rings), has muddy transmission fluid and the front struts are stiffer than uncooked spaghetti. I'm in the process of performing a tranny flush and wondering whether there is a filter that is replaceable. I did ID the part number that the dealer provided and have seen that it exists (in-line housing with filter element as a single unit). However, I (as an amateur DIY) can't locate it. If someone can comment on A. whether or not it's accessible without major work and B. whether I should mess with it at all. Thanks and best regards, Craig
Old 10-07-2020, 02:19 PM
  #157
kevin2m4's Avatar
Hi
Muddy transmission fluid?
Is it like brown and foamy?
Take the rad cap off and if there's brown foam in there you have a cracked radiator and it needs to be replaced and the trans and rad flushed asap.
As far as the filter the only one I can see is in the trans. My TL had an inline one under the battery tray. I have pics of it somewhere...
Old 11-05-2020, 09:57 AM
  #158
kevin2m4's Avatar
Doh
Old 11-12-2020, 01:59 PM
  #159
CSmoney28
CSmoney28's Avatar
Wink
You're exhaust rusted and fell off damn...also can you send me the info on those bulb sizes please...you put the wrong oil in your RDX it is lubricated by the oil that's a poor choice. You should be putting in HT-06 Mobile 1 fully synthetic this is not an average Acura motor and demands the right oil.
For the other gentleman making suggestive jokes about his girlfriend you need to do the transmission flush every 30,000 miles if you want it to last like mine that has 150,000 miles on it now.
Old 11-12-2020, 02:57 PM
  #160
kevin2m4's Avatar
It looks like the hanger broke off at the end of the midpipe at that compression fitting and out pressure on it but yeah rusty. Coat hanger will hold it in place until I get one of those cheater brackets
The bulb I just stole from the airbag light and moved it into the mode button. It's a different bulb but it fit and was free and didn't really affect anything. And yeah I know I'm using the wrong oil. It's sort of bugging me, I'll change it out early maybe. That certification is for how the oil travels through narrow passages under pressure when it's dirty right?
Quick Reply: Unconventional RDX Build
