Ugh, 2007 a/c issue:-(
Hi,
I think my a/c is bipolar(lol). When it works it will freeze you out and when it doesn't you will roast. I am looking at other threads about replacing the field coil. Does replacing the field coil help with the other problems I'm having:
1) It may/may not work when first starting up. If it does come on, the full blast of cold air last anywhere from 5 mins to 45 mins, then the air blast will kick down and throw out warm air then hot. Sometimes I can tell when its getting ready to go to warm air cause it will smell funny and feel damp. After awhile it may/may not work again.
2)When its blasting out cold air and I turn down the fan, or change modes, it will blow out hot air.
3)It will blow out hot air after I turn it off.
Thanks for any replies
I had a similar problem and it turned out to be caused by a relay. Not sure which one, but both are located in the fusebox under the hood. There is a thread on here related to what I am alluding to, if I can find the old part I will repost.
I swapped the relays w the upgraded one and have not had an issue for about 6 months.
Biggie_B
May 27, 2025 05:51 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
