Transmission and differential change 2007 rdx
Sick of paying the Stealership.
I want to change the differential and transmission fluid.
What fluids do i use, do i need crush washers, a pump?
Are there any filters to change?
And how much fluid do i need.
I live in Canada and did not want to buy them at the dealership.
Thanks - i also own a 2011 mdx and will be doing the same.
help pls.
help pls.
DIY RDX Transmission Flush:
https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-transmission-fluid-flush-3x-drain-fill-794451/
DIY RDX Rear Differential Fluid change:
https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-rear-differential-oil-change-776568/
See you owners manual, the MID will tell you when to change fluids...etc
mada51589
05-03-2022 08:54 PM
