Side mirrors angling down in reverse
Hi,
My passenger side mirror angles down when backing up, but my driver's side does not. Does anyone know if the driver's side is also supposed to angle down when the vehicle is in reverse?
Looks good, drives great!
I believe that the selector switch drives which mirror goes down (ie if driver's side mirror is selected, then that mirror goes down and vice versa).
Only the passenger side mirror will tilt. The selector has to be set to the passenger mirror for the passenger side mirror to go down. If it is in the driver or neutral position, the mirror will not tilt down.
True story. I wish both would, or at least the option. My friends CL did.. not sure about other models.
Ha ha, I'm the idiot that took it in cuz it "stopped working" after owning my '07 RDX for a week or so, I noticed it wasn't going down... only after I fiddled with that toggle switch... Luckily that wasn't the main thing I was having it serviced for - some other warranty issues. Anyway, I'm not sure my driver's side goes down if that toggle is switched to that side... I'll be checking that tonight
I am surprised they bothered to omit the driver side on this feature. TL, RL, MDX, ZDX will tilt on either side, but not, at least the early RDX. I no longer have access to Honda OM, the site seems to be closed to me now.
Does anyone know if they deleted the driver tilt feature on the TSX?
From the 07 RDX manual
Reverse Mirror Tilt
With the selector switch in the R
(right) position, the passenger’s side
mirror will pivot downward slightly
when you shift the transmission into
reverse. This gives you a better view
of the side of the vehicle while
parallel parking. The mirror returns
to its original position when you take
the transmission out of reverse.
Turn this feature off by leaving the
selector switch in the left or center
position
Reverse Mirror Tilt
position
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
