Service intervals. Maintenance Minder.
I've got several questions while reading the Manual (page 343. Maintenance Minder).
Are the air cleaner and dust&pollen filter both called Cabin Air Filter ?
What's the drive belt?
Should I use ATF-Z1?
How often should I replace the sparks? What's the valve clearance?
Once again. How often should I perform the replacement?
Once again... Should I use ATF-Z1 ?
Symbol 2:
Replace air cleaner element...
Replace dust and pollen filter...
Inspect drive belt...
Symbol 3:
Replace transmission and transfer fluid
Symbol 4:
Replace spark plugs
Inspect valve clearance
Replace spark plugs
Symbol 5:
Replace engine coolant
Symbol 6:
Replace rear differential fluid
Well, okay... I've seen several archived posts with the similiar questions w/o just any reply. I do sincerely hope that smb from the dealer-shop is reading this thread & give an advice.
Here's what I got from the neighbour forum
TSX maintenance schedule: https://acurazine.com/forums/showthread.php?t=24744
Is it possible for any moderator to move this thread to the Acura RDX Discussion forum (https://acurazine.com/forums/acurazine-articles-2/) because I'll never get an answer here. Thanks a lot.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
