Reverse light wire color
Old Dec 4, 2018 | 06:06 PM
airlyss's Avatar
Hey all - I'm in the middle of installing a backup camera in my 09 Base and can't seem to get power to the camera. I've run all the wiring, but for some reason can't get the camera to kick on!
Am I tapping the right wire? The reverse light cable has a black and green wire - I tapped the green wire assuming the black is ground, but is that right? Thanks!
Old Dec 4, 2018 | 06:36 PM
use a multimeter to test..
But i think green is ground, black is hot.
Old Dec 4, 2018 | 07:09 PM
airlyss's Avatar
Thanks - I'm doing the job on my own so can't figure out how to use the multimeter while having the car in reverse!! I'll try tapping the black wire to see if that works, though it would be very confusing if black was live - it seems like black is ground in all the other connections I've tested with the multimeter.
Old Dec 4, 2018 | 08:31 PM
Car in accessory mode (aka not on) , e-brake on, shift to Reverse, go test, profit.
Old Dec 9, 2018 | 01:33 PM
airlyss's Avatar
Thanks! Got it installed after many hours and cuss words
Works great, thanks for your help!
Old Feb 2, 2020 | 03:46 PM
Lin Zhou's Avatar
Can you please advise your successful identification of MDX reverse light wire: Hot wire (+12v) vs. ground?
My 2012 MDX base has Brown color wire and Black with silver dash wire. My purpose is to find the triggering wire (taping to the wire of dash camera).
Thank you!
sockr1
Mar 2, 2024 03:56 PM
sander
Jan 17, 2007 09:07 AM
NyRider
1G TL Problems & Fixes
Mar 22, 2006 07:52 PM
