Replacing Fuel Filter...
Acura Parts Guy
It's not a servicable filter like you're probably used to. 91+ octane and the occasional fuel additive should keep it working like new for a long long time
The filter set is an integral part of the fuel tank unit (center of picture). It should be replaced if the fuel pressure drops below the normal range of 47 to 54 psi, if the pump and pressure regulator check out OK.
Don't buy cheap gas.
cycdaniel
12-17-2019 10:58 AM
NBP_BALLER
09-23-2015 08:18 PM
