Rear Brakes/rotor caps rusting
Old Aug 30, 2010 | 08:53 PM
HabsFan's Avatar
5th Gear
I have a 2007 RDX and the caps or covers for the rotors? (not exactly sure what they are called) are rusting. Attached is a pic. It just doesn't look good, so I was wondering if it was normal or what I could do to fix it. Do I just need to replace them?
Bigger pic here: http://i39.photobucket.com/albums/e1...dek/brakes.jpg
Old Aug 31, 2010 | 09:54 AM
moltonbrown's Avatar
normal... fyi the 2010 had them "upgraded" for better corrosion properties - hence i presume honda knew about this problem already (otherwise, why the upgrade)...A new “Geomet” coating on the rotors prevents corrosion, ... added fyi: there are quite a few subtle differences btwn 07 vs 10 in terms of little things -- better road feel (less harsh), the geomet coating fwiw, rear view camera as std, etc etc...
you may want to paint the cover if youre into it... personally, i wont sweat it
Old Aug 31, 2010 | 06:11 PM
HabsFan's Avatar
5th Gear
Thanks for the info. If its normal and not going to hurt anything I'll just leave it as is for now.
Old Aug 31, 2010 | 09:43 PM
737 Jock's Avatar
haole kama'a-ina
Lightly sand and paint the rotor hat and lip with POR-15. It will provide a gloss surface for the life of the rotor and a few years after that. (You could make a clock out of it ).
01CLOwner
Oct 9, 2015 01:07 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
IIDXholic
Oct 8, 2015 07:53 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
max4swag
Sep 14, 2015 07:55 AM
