RDX Service Manual
RDX Service Manual
I got my RDX service manual in the mail today. Wow what a book! To say it is phone book sized would make it sound smaller than it really is I think. I almost have trouble picking it up with one hand. If anyone needs any info from it, let me know... It looks to cover everything you can imagine. Except of course all those features that aren't there that we would like....
Nice...might have been useful for the service tech that worked on my ride. He didn't have any wiring diagrams for the seat heaters. Noticed the high setting on my passenger side wasn't working so he had to trace the wires back by eye.
Also didn't know the GPS has its own antenna in the dash while the AM/FM/XM share the antenna on the roof.....
I think the book was $75 plus shipping of $6.??.
Originally Posted by sasair
Dang, how could an acura service dept not have the service manual? Just out of curiousity I looked up the seat heaters. I didn't know the driver seats has a heater in the seat cushion and the back rest, while the passenger seat only has a heater in the seat cushion....
Mike
Originally Posted by saknife
Where did you buy the manual from? And how many pages it is really?
The pages aren't numbered as a whole, but rather by sections so it is hard to tell.
http://www.helminc.com/helm/Result.a...T71TWTB5M93T6D
I found printed in the front of the manual that it says it has 2704 pages, but I didn't count them to verify.....
Community Architect
robb m.
robb m.
Originally Posted by mairdx
Question, Does track control needs to be on or off ? I just bough rdx last saturday.
VSA® helps keep the RDX on track during fast or tight turns by detecting and correcting potential understeer or oversteer. The system continually monitors vehicle speed, throttle position, individual wheel speeds, steering angle, lateral g-force, and yaw rate to detect when oversteer or understeer is imminent. When necessary, VSA automatically reduces the engine’s torque and uses the ABS system to apply brakes to each wheel, as needed, to help stabilize the vehicle. The response is so quick that the instability may be corrected before the driver even knows it’s occurring.
Traction Control is integrated into the VSA—and in tandem with SH-AWD™—helps the RDX accelerate smoothly on slippery surfaces. Any wheel about to break traction upon acceleration will have its brake applied and/or power diverted from it until secure traction is regained.
Missin my TSX =(
dude u are the best man, i called helms and asked them if book had a few things i need for my remote start before i bought it, and noone seems to know what im talkin bout.... i hope u can help me please... this is what i need from the manual... detailed wiring diagrams of the following:
1) tachometer wires in the ECM/PCM
2) unlock and lock wires in the kick panel
3) hood pin sensors
4) door pin sensors
5) sunroof and window wirings
can u tell me if these wiring diagrams are in the manual? if so, is it possible for you to scan them for me, im willing to pay you per page if u want
3) hood pin sensors
4) door pin sensors
Missin my TSX =(
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Originally Posted by chyllintsx
my dealer doesnt have it either, i asked them for copies before i asked you ![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
I'll take a look for those things you requested but give me a little while to look it up. I'll try to get back to you as quick as I can...
Missin my TSX =(
I'm sure your dealer has the manual, its probably more like they weren't willing to copy it for you....
thanks for helping me out man, i really need them, let me know whenever i find them, shoot me a PM or something, thanks i appreciate it
Can you down shift when you are on freeway with 65mph ? Also can you change to s mode when you are on freeway with 65mph or you have to stop to change to s mode ?
yes you can downshift on the freeway doing 65mph. I'm pretty sure 3rd gear will handle 65 mph just fine, but I don't know about 2nd.... the manual says you can take 3rd gear up to 94mph, 4th gear up to 114mph. That's on page 302...
the traction control lite on, is it on or off ?
The light should be off on the VSA Off button for normal operation. when you turn the car off and back on, the VSA system will turn itself back on(light off) regardless of what condition it was in before you turned the car off. You should not have the triangle with an "!" in it or the VSA indicator light on on your dash. this indicates either a problem or that your VSA system is off.
Investigating how to install USA Spec iPod adapter. Does the manual show how to remove the stereo?
Any other input would be appriciated.
mdx_bob
Originally Posted by rdx_bob
Just got my RDX on Saturday 6-30-07. Great car(truck)
mdx_bob
mdx_bob
Instrument Panel/Cluster Panel
Sasair,
I destroyed my instrument panel/cluster in my rdx with a piece of lead pipe (by accident) and need to replace it. Any chance you have the replacement instructions in that service manual for this? I tried to pm you but apparently my access level does not allow for it. Thanks in advance.
Or...with the manual it can be done without trouble.
Caution: the audio unit is tied into Navigation and Telematics, and is in close proximity to the Supplemental Restraint System computer. Specific warnings and procedures apply to the SRS.
No one should do this without the manual.
Sasair - Need Instructions for Fog Lamp Replacement
Sasair - you're always a great resource.
Can you post the instructions for replacing a fog lamp.
I took a rock into one, and will be replacing next weekend, when I install the new front spoiler that just arrived this morning. I want to do it all at once.
Part of the spoiler installaiton is removing and re-installing the fog lamps. I just need to know if there are any tricks.
I don't plan to disconnect the battery for the spoiler install. I'm hoping that the fog lamps can just be unplugged, attached and reconnected.
Since you have to remove the fog lamps in order to install the new front under spoiler, it will be a piece of cake to change the fog lamps. They just screw onto the back side of the spoiler with three screws.
Here are the Front Under Spoiler instructions which show how the fog lamps connect:
https://hondacuraworld.hostasaurus.c...xfrontsplr.pdf
Ukrainian RDX
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
Hey, sasair. What about an idea to share the RDX Service Manual with the whole world. You're gonna be the hero ever!
http://www.scribd.com/paper
Convert Your Paper to iPaper is a program at Scribd where we will scan your paper documents and publish them on the internet completely for free. You just send us the documents in the mail - we'll take care of the rest.
Ukrainian RDX
Originally Posted by Fishbulb
Because its copyright infringement.
Originally Posted by Azzie
There are thousands of manuals there at Scribd and publishing the scanned parts of this manual on this forum, i.e., is also a "copyright infringement" BTW. So okay, let sasair to have his own decision.
Ukrainian RDX
There's also millions of anonymously posted movies and mp3s on torrents, etc, but the difference being is that someone isn't dumb enough to suggest that a moderator of a forum, who could be easily traced, load up copyrighted material in its entirety, and take credit for breaking the law.
but my manual haven't yet arrived and I could not see the copyright notice in it. Or did You?
