RDX 2010 AWD: Noise and Lag questions
Hi there,
I am looking to purchase an Acura RDX 2010 AWD with TEch Package (cannot afford the MDX right now).
When I test drove the car, there was a strange hissing noise from the engine when flooring the accelerator. It was loud enough to be noticeable. I am wondering if that is usual for the RDX, or if it was just that particular car. I do not have a car and do not want to go to the dealership again if the noise is an issue.
Also, is there a Turbo lag when the car is accelerated. I have read many comments relating to this, and just wanted to see how that impacts the driving ability.
Thank you for your help. Best wishes,
Ash
Ash
Carbon Bronze Pearl 2008
Hi there,
Ash
Ash
Once one gets used to the RDX turbo the lag is minimal or practically gone. The RDX seems to perform better by easing into the throttle instead of just mashing the gas. It's a damn fast little CUV.
The "strange hissing noise" you hear is normal. The RDX is a TURBO. The hissing noises are the spooling of the turbo plus the air rushing in. It's normal. Many RDX owner enjoy the sound.
Thank you again for your help.
not an SUV ...a Big Hatch
without knowing exactly what you were hearing,
...drive it some more. if you're for the car, you'll know right away that it is for you.
Maybe drive one at a different dealer. if you still hear the same thing, and it is just in fact the slight factory turbo spool, just pay attention to the drive.
El Chulo...
pssssshhhhhhhhhhhhhhhttt!
Ash if you think that RDX you test drove was loud, you should hear mine with the cpe air intake... you can hear my turbo whistling from down the block!!!! The RDX being turbo was one of the main reasons I leased and then refinanced after my lease was over. I have enjoyed my turbo CUV for 3 full years and many more to come.
to the OP, carbon's comments +1 per my own experience. i didnt find any turbo lag to be "unsafe" for normal driving conditions (knock on wood but this is no toyota).
for the hissing sound, i think it's actually cool. if you dont want it, just turn up the radio LOL. the sound system "automatically" adjusts to your speed, accdg to the owner's manual.
Hi VeNeNo, That is funny. Well the thing is that if I hear a noise like that, I think the car has a problem. This is my first car, so I am probably a little more concerned. I would think that the noise cannot be good for the car, but you have not seen any reliability issues with the car / engine, have you? I am a "system" person so I would get the oil changes and maintenance as per the recommendations, but is that going to be enough?
What does S and D mean
Also, could someone please tell me what paddle shifters are? Is that like manual transmission? I feel like I am in kindergarten here.
S mode = sport Mode. Transmission will shift gear at higher rpm compare to "D" mode
D mode = normal driving.
Paddle shifter = same tech for F-1 cars, you can downshift or upshift gear using this paddle.
S mode + paddle shifter = Manual Transmission.. :p
Also, in sport mode the 5th gear is NOT used. Only 1 thru 4. For highway cruising, use "D" mode for more efficiency.
corduroygt, I am not sure I understand what D and S mean. I am sure this is a fairly basic question, but please clarify as and when you get a chance. Also, what do you mean by Flat footed?
Flat footed = gas floored yet the car doesn't move right away.
nsl752
14
12-06-2016 07:32 AM
rockyboy
01-25-2016 06:00 PM
