Please help! 2007 RDX Tech - Central display is not working
Old Jan 24, 2021 | 12:11 AM
Sicota's Avatar
5th Gear
Smile Please help! 2007 RDX Tech - Central display is not working
Hi everyone,
My car is 2007 RDX Tech package. When I picked up the car two weeks ago, the display of Navigation and Backup Camera didn't work at all. All the buttons at Dial Interface were not functional. However, I can see some light for the screen backlit, and the radio + aux is still working properly.
I brought the vehicle to the mechanic and here was what they tried.
  • Unplugged the battery (negative cable) for more than 30 mins => Not working
  • Checked all the fuses (under the hood and under steering wheel => All fuses are connected properly
Finally, they told me that the stereo module is broken and advised me to look for a used part to buy. I’m looking up stereo module for this model but I’m not sure whether the search results are I’m looking for. Can anyone help me please?
I make a video about the center screen when I started the vehicle. Please feel free to give opinion if the problem is something else.
Here is the photo just in case the video doesn't work.
Nav + Back up camera screen doesn't work.
Much appreciated.
Old Jan 24, 2021 | 09:20 AM
CSmoney28's Avatar
CSmoney28
Audio Unit
Old Jan 24, 2021 | 09:22 AM
CSmoney28's Avatar
CSmoney28
Navigation System
Old Jan 24, 2021 | 07:54 PM
Sicota's Avatar
5th Gear
Hi @CSmoney28 ,
Thank you for the links. I'm not sure if the Audio Unit is necessary since the it is functional.
For the Navigation System, there are many parts in it. Can you please let me know which part I should go with?
Thank you.
Old Jan 26, 2021 | 12:27 PM
CSmoney28's Avatar
CSmoney28
Please give me more specific diagnostics if possible, thank you!
Old Apr 20, 2021 | 07:08 PM
Sicota's Avatar
5th Gear
I don’t have much information about the diagnosis. My mechanic guessed the problem is about the nav screen. He tried to change that with the replacement ordered from ebay. Same issue, it didn’t work.
I think the problem is about something else related to electricity. What is the best option now?
Old Oct 17, 2021 | 01:48 AM
Sicota's Avatar
5th Gear
The issue has been solved. After having the service manual, I figured out the solution.
=> The navigation unit (the DVD player bottom the central console) needs to be replaced. I found the part and it works.
Case closed!
Laine Bassin TV
Jan 29, 2021 12:40 AM
renvelaz
Dec 6, 2018 11:23 AM
Tuffcat
1G RDX (2007-2012)
Nov 8, 2016 06:32 PM
dcrdx
Feb 22, 2014 10:59 PM
K_SETHURAMAN
Jun 2, 2012 08:10 PM
