o2 sensor air fuel ratio Bank 1 Sensor 1 Location
Old Mar 4, 2017 | 04:24 PM
sjarvis028's Avatar
Does anyone know where to find the O2 sensor in Bank 1 Sensor 1 for the 2009 RDX? Have the part on order and would prefer not spending $200 in labour for an easy fix.
Much appreciated
Old Mar 6, 2017 | 08:43 AM
Tomtwtwtw's Avatar
Ignore the "bank 1" reference since all RDX only have 1 bank of cylinders. The "sensor 1" should refer to your upstream sensor, generally placed very close to the engine (make sure you ordered that and not your downstream sensor that plugs into the exhaust after your cat). Typically it'll be between the turbo and cat(s), but I couldn't tell you what direction it's facing, whether to approach from above or below, etc. I haven't had to explore this are of my RDX yet but I have changed it on other cars before. If you peek at the turbo and follow the path down the exhaust, you're sure to find it.
Old Mar 11, 2017 | 02:52 PM
TheWrench116's Avatar
FLETCH
think of this as the perfect opportunity to upgrade to an RV-6 down pipe!! seriously though this sensor is between the turbine housing and the primary cat.
Old Jan 30, 2023 | 05:27 PM
tigersfa8's Avatar
Much appreciated
Did you find where this is exactly located? I just recently found that I needed to change it, and can't find any actual pictures or youtube tutorials for the first gen Acura RDX.
Old Jan 30, 2023 | 10:32 PM
DaIll1's Avatar
At the pre-cat, between the engine and firewall
https://acura.oempartsonline.com/v-2...ine--converter
Old Jan 30, 2023 | 11:17 PM
tigersfa8's Avatar
To clarify, is this accessed from the bottom before the catalytic converter?
Thanks!
Old Jan 31, 2023 | 01:20 PM
DaIll1's Avatar
Thanks!
Sorry, just answering your question of where it is, not giving advice on how to get there. I've never taken that journey.
Old Feb 3, 2023 | 11:12 PM
tigersfa8's Avatar
Was able to find the top O2 sensor and being my first time performing it, took a bit of time.
Steps:
1. Remove the Intercooler. I used this youtube video to remove the intercooler (not too difficult and removing it from the rubber hose was the only difficult part) -
2. Remove the heat shield of pre converter (behind and left side of engine when standing in front of engine)
Then you will find the O2 sensor, and the wiring.
3. I used this youtube video for how to remove the O2 sensor:
I have attached a photo here and it is behind and below the green circle (you can remove this housing mount for easier access
TSXnoob73
1G TSX Problems & Fixes
Mar 14, 2019 05:13 PM
Algavin
Dec 23, 2017 12:29 PM
acutee
Jan 30, 2009 10:11 PM
lcrazyaznl
Oct 17, 2006 11:02 AM
richarfg
2G CL Problems & Fixes
Nov 9, 2005 02:48 PM
