New member with 07 RDX tech package
Just wanted to introduce myself and ask what are the common pain points to you seasoned owners?
I’m Tim, just picked up a one owner 2007 RDX w/tech package with 107K miles on it.
Not new to the Honda/Acura family.
I replaced the following upon bringing her home, all genuine fluids and filters.
Spark plugs
Coolant
Engine oil and filter
Transmission fluid
Rear diff fluid
Transfer assembly fluid
Cabin filter
Cleaned debris and straightened fins on intercooler
I've ordered new floor mats(fronts were missing), four door speakers and two satelite(rear) speakers, both sun visors.
I will be picking up serpentine belt today, it also needs brakes all the way around, may have to replace the rotors, depending how warped they are and if there’s enough material to true them up.
It runs and drives fine, just want to know areas where I have to pay special attention to.
Anyways, thanks ladies and gents for any and all input.
Tim
Spark plugs
Coolant
Transmission fluid
Rear diff fluid
Cabin filter
Tim
CSmoney28
Replace the coil packs as well since they may fail no use removing the intercooler twice.
Check all hoses especially the abs and broke hoses tend to go bad.
Always put new rotors on when you change the pads the rotors will warp on this heavy truck.
More info if needed...
Tlarimer (01-07-2020)
