new engine oil every 4 months - rdx runs like new
Old Apr 18, 2011 | 09:38 AM
mav238's Avatar
I just changed my engiine oil and filter on Friday, about 4 months since the last change. The MID was showing 40%, my wife does not drive the rdx too much, but lots of city and hill driving. After 4 years, the engine still runs and sounds like brand new. Pennzoil platinum is a really good synthetic oil.
Total oil change cost per year = $100. well worth it.
Old Apr 18, 2011 | 05:14 PM
dcmodels's Avatar
Originally Posted by mav238
... After 4 years, the engine still runs and sounds like brand new. Pennzoil platinum is a really good synthetic oil. ...
How many miles on car? consistent use of Pennzoil?
Old Apr 18, 2011 | 06:16 PM
mau108's Avatar
you should just follow the MM it takes in to account short distance drives, stop and go's etc...
I've been running PP since I got the RDX as well, looked under the oil cap its soo clean I can eat off of it. Got 77K on it now.
Old Apr 19, 2011 | 01:54 PM
mav238's Avatar
True, but at $30 per oil change (DIY), spending $100 per year to keep engine running smooth and like new is well worth it. Plus, every time I change the oil, even after just 4 months, it is quite dark coloured, it is definitely doing its job in cleaning up the engine.
Old Apr 19, 2011 | 10:03 PM
kingkong222's Avatar
If I had the time and dedication like y'all do. I'll be changing my 335i once every 7 months.
Old Apr 20, 2011 | 06:09 AM
windowlickingood's Avatar
anyone have a UOA with the penzoil yet?
Old Apr 20, 2011 | 06:14 AM
nj2pa2nc's Avatar
it's a car-drive it
I am also wondering how many miles.
Old Apr 20, 2011 | 08:38 AM
DJ Iceman's Avatar
I'm not faulting the OP for his obsessive oil changes or the positive results, but my RDX is also coming up on four years, has only had service done when the MM got to 5%, and also still runs like new!
Old Apr 20, 2011 | 09:41 AM
JCRDX11's Avatar
What is the correct time to change the oil on our RDX? I am down by 20% - I normally change around 15 - 20%? My car has 5k in miles on it.
Old Apr 20, 2011 | 10:32 AM
mrgold35's Avatar
mrgold35
I usually wait until I'm under 10% for both the TSX and RDX before I set an appointment at the dealership to change the oil. I purchase my own Mobil 1 oil for both vehicles from Walmart to save a little $$. They get it done in a few hours and they wash the car afterwards.
I have a bad habit of not checking my oil between changes. Make sure you are in a safe oil level when you are getting close to change time.
Old Apr 20, 2011 | 12:11 PM
valleverde007's Avatar
ive changed my at 15% (most likely <15% to be precise). now it's at 20% (will prolly turn to 15% this wkend) and ive set an appointment for next wk to be changed again.
i too havent checked my oil since it was prolly still at 80-90% so ill have to check it tonight. thanks for the reminder.
at 15%, my rdx usually has done 4.5-5k miles as well
Old Apr 21, 2011 | 10:07 AM
JCRDX11's Avatar
Just when I post this question yesterday; I started my car and the B1 code reminder came up to go have my oil change. lol
Old Apr 21, 2011 | 01:30 PM
must be some kind of "curse". i had my 15% B1 light up yesterday afternoon as well, after i posted!
Old Apr 22, 2011 | 04:58 AM
Kaze66218's Avatar
Copy cat shinobi
Mau is the guy to talk to. Mau you are a BTOG forum right any info?
I hear Penz platinum is really good, Mau reccomends it. I am RP
Op oil always does that. there are oil passages that "durty" it up right away and really there is no way of visually seeing the particles,as most are traped in the oil filter. Exhaust smell is normal too. I cracked my h22a4 open to pull the crank, rods, and pistons out and well in there oil can get trapped in the "hallows" --bolting holes-- of the block and get noxious... I had a head ache every time I was in the garage until it aired out 8-9 days later.. swore I could smell it in the house
anyway there is enough time for it to get dirty but it is about 60 it's life.
Old Apr 22, 2011 | 05:05 AM
^ royal purp? *runs* its rather funny, i asked the service manager at my local dealer and wanted to know if they really filled with mobile1 and they cringed and said no. the dealer fill is rotella. I personaly would not run mobile or rp.
Old Apr 22, 2011 | 09:10 AM
mau108's Avatar
If your dealer is filling your RDX up with Rotella then they are voiding your warranty.
Rotella does not meet the HTO-06 standard set by Honda specifically for the RDX. Rotella is good oil (T5 and T6 both) but unfortunately if you care about warranty its not the oil to use.
Kaze66218 I know what you mean by the smell, I had an oil catch can on my Prelude and cleaning that out it would smell especially with all the moisture mixed in, it would smell and look like salad dressing lol.
Once a week take your cars to fuel cut off (~6800 RPM on the RDX) its good for it especially if you or your partner drives very conservatively rest of the time. I did this with the prelude, I do it with the TL and I try to do it with the RDX when ever I drive it and so far no issues with the motors on all 3 cars (sold the lude with 216K on it and motor was mint!)
Old Apr 22, 2011 | 09:18 AM
Well if they are doing changes with rotella, then im sure if something goes on they are not going to void the warrenty. That would be a massive law suit if they did with documented changes at the dealer. but regardless, any syn with a proven uoa that can show that the motor is showing proper wear results then it should never be a issue
Old Apr 22, 2011 | 10:27 AM
Kaze66218's Avatar
Copy cat shinobi
...Kaze66218 I know what you mean by the smell, I had an oil catch can on my Prelude and cleaning that out it would smell especially with all the moisture mixed in, it would smell and look like salad dressing lol.
@Mau, Did you ever crack the block open, inside there are passages and bolt holes under(above if in the car) the crank around the bearings. Dark black evil oil from 1997! Exhaust smell was like a 10-15x concentrated just for me, ran me out of the garage after 2 mins. Mid winter with temps at 20* I swear that has to be the original oil in those passages and the circulation was horrible in those areas. I agree RP is over priced.
I should have taken a picture of the short block before I had it sent out for machining. After 30,000miles I switched to RP, the engine was pristine and zero deposits with healthy bearings but it's not just a oil that got me to that point it was also a regular filter change.
@those who don't know this...Oil is important to change at recommended intervals but I never see how anyone stresses how important changing the oil filter is, thinking of all filters, there maybe one that may be better than the other but replacing them every other oil change is better than changing the oil every 3000 miles.
@OP... A good item for anyone that has OCD for oil change is a magnetic oil and tranny plug from Blox/Kics/NRG/S2/????"google it etc."
I'd love to tell you where to get them but cheapest place changes everyday.
There are a few variations of this Neo or ceramic magnet (Neo being stronger) but an OCD'r person should have one of these too.
Old Apr 22, 2011 | 06:57 PM
JCRDX11's Avatar
I just pick up some Mobil 1 and change my own oil today after work. (first time)
I use the DIY guide and it was easy.
No more paying $80 for a oil change! lol!
mada51589
Jan 9, 2025 04:40 PM
Fabian43
Jul 13, 2016 09:07 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Allen_442
Sep 8, 2015 06:01 PM
