Low frequency whining noise, Rear shaft drive bearing failure?
Old 10-20-2018, 07:47 AM
6th Gear
Mwkaraffa's Avatar
I think I'm hearing a low frequency whine noise in my 2009 RDX AWD, 64k with the pitch increasing as the speed increases, but still not a high pitch. I say "I think" I'm hearing the sound because it is so benign and sometimes I think it might just be road noise, but over the last month or so it seems to be more noticeable. No whining noise when idling at a stop, and shifting to neutral while driving doesn't eliminate the noise. I think it may be the rear shaft drive bearings, and if that's the case:
  • I'm pretty good mechanically, (Brake jobs, starter replacement) so what is the difficulty level in replacing the rear drive shaft?
  • What should I expect to pay for the part, and any suggestions as to where to purchase?
  • If I can live with the noise for now, will the drive shaft fail without warning and leave me stranded?
I appreciate any advice that anyone can offer on this!
Old 10-22-2018, 12:48 PM
Tomtwtwtw's Avatar
Are there any dyno shops in your area? It may be worth paying for an hour of time and being able to listen all around your vehicle while the wheels are turning to find out for sure where the noise is coming from.
Old 10-22-2018, 10:45 PM
CSmoney28
CSmoney28's Avatar
Maybe, it’s the rear axles.
Did you look under the vehicle and check for loose parts?
Can you take a video so we can help you diagnose your problem?
Old 10-30-2018, 09:08 AM
bluetroll's Avatar
Does it get louder when in either direction of left or right?
If it gets louder when you turn left, it will be a right wheel bearing. If it gets louder when you turn right, it will be the left wheel bearing.
Old 11-15-2018, 06:30 AM
6th Gear
Mwkaraffa's Avatar
Yep, it was the front driver's side wheel bearing. Thanks for your help!
chefmatt
03-23-2018 01:09 AM
burnyd
01-03-2017 12:18 AM
WSZsr
2G RDX Problems & Fixes
10-11-2014 07:10 PM
bayridge_golfer
11-09-2011 12:13 PM
photonbeam7
02-16-2007 09:22 PM
Quick Reply: Low frequency whining noise, Rear shaft drive bearing failure?
