K&N Engine Air Filter...which one to get?
It's time for me to change the engine air filter on my 2007 RDX and I want to go K&N this time because it's washable and reusable.
I found 2 available to me online both at decent prices but I'm not sure the difference between the two
1. http://www.autopartsway.ca/PartDetai.../pagenum1/tabS
2. http://www.autopartsway.ca/PartDetai.../pagenum1/tabS
Their dimensions are a little different.
1. 8.50 x 1.50 x 17.50 inches
2. 1.75 x 17.19 x 8.31 inches
Correct me if I'm wrong but I recall the OE filter has dimensions of: 7.50 x 2.00 x 14.00 inches
Does anyone know the difference and which one would you guys recommend?
mrgold35
http://www.ebay.com/sch/?_nkw=acura%...os=87120&gbr=1
It should only cost you $45-$50 total (tax and shipping) if you order on-line from eBay. You might want to check locally and they might have it at Autozone. You need to pick up a cleaner kit anyways. I usually clean my K/N in the spring and fall for both my RDX and TSX.
Aside from that, do you know what's the difference between the 2?
i picked mine up from canadian tire, special order. not that i recommend getting anything done at that place. avoid canadian tire auto service at all costs.
So my question still comes down to what's different between the 2...
i don't know but it would not make any difference. k&n uses oil to filter which is not always effective. washing and reapplying oil is tricky and can lead to leaks that contaminate sensors. i recommend staying with oem. you won't see any gain with k&n filter. If you want results get the k&n intake, they claim about 8.7 additional horses:
![](http://www.knfilters.com/news/news.aspx?id=1600)
ofc thats not 8hp increase at all times, that's the MAX gain. overall you will get a smoother torque curve:
![](http://img37.imageshack.us/img37/8404/80686548.jpg)
I have yet to find a washable/reusable air filter that is worth anything. They don't catch particulates NEARLY as well as a pleated filter. If it isn't catching at least as much dirt, it is because it is letting it pass right into the engine ... that's a bad plan.
Want to save money, buy a non-OEM pleated filter.
does it sound legit?
the RDX is very easy to tunes, specially pre 2009 models. start with hondata reflash, you could get this done in toronto easy, but car might have to be garaged for a few days. Intake and exhaust mods, such as k&n and atlp catbacks are definate gains too.
this is a video from one of our members here, intake and hondata mod, notice sub 6 second acceleration to 60 and great sound:
http://www.youtube.com/watch?v=K5b9F...layer_embedded
there are tests where one removes filters altogether with no increase in power/torque. just Google it. if you want gains, CAI is the only way under for about $300 or less.intakes and exhaust upgrades greatly help forced induction engines to take advantage of extra breathing capability. On NA cars even sometimes CAI and exhaust upgrades produce no gains, only way would be to upgrade headers, lighter weight pulleys, more aggressive camshafts etc.
Copy cat shinobi
If I may also add search google "K&N air filters MAF problems" forums. Even one on here. Wlgood made a clear point, I observed the same gaiping holes with mine at 10000 miles. I highly recommend using a AEM dry flow filter with the charge tube from K&N typhoon kit.
Knn drop in is good, but when it's time to replace it just buy a new one, because you'll need a cleaning/oil kit for it, so you'll need to buy that, cleaning is easy but re-oiling is a pain and a mess, because the re-oil bottle is not a spray, it's more like a stream and you'll need a brush to spread thw oil, in the end it will be over-oiled.
Not sure we're you're buying the recharge kit, but my re-oil bottle is a spray.
rockyboy
12-06-2022 02:29 PM
