HOW TO: Mirror Re-install
Old Apr 24, 2018 | 11:34 AM
Josh Pratt's Avatar
4th Gear
** my giant thorough post didnt autosave when my battery died so heres a brief overview. ask any questions ill be more than glad to help.
SO i recently tried to fix my mirror actuators and broke two driver mirrors and an actuator in the process.
To save your self some $$ and frustration i wanted to share a little trick i found super helpful when reinstalling the mirrors
There are 4 tabs you need to press into the actuator plate and it is a very tight fit.
Take a dremel and sand down the lower inside (closest to the window) tab and the mirror slides right in and hold very well.
Make sure to use a heat gun to make the adhesive tacky again and it makes for a super easy, stress-free, SECURE fit.
included are some pictures of the mirror and actuator (the driver actuator is like $85 shipped and i was pissed when i opened it to see what was inside)
in the attached pictures the tab with the RED circles/highlights are the one you want to make flush. the BLUE is other tab found on the same side. you can see its a small amount of material that you need to remove
Blue tab is the original untouched tab the red one is sanded smooth
Red circle denotes tab to sand smooth
Driver mirror and mount plate that is part of the actuator subassembly. theres a peg/pin that lines up with the hole in the mounitng plate.
Mirror actuator motor. central shaft broken (you can kinda see that) on removal
Power rails connected to 2 - 6V DC motors . this gear train is threaded in central axis of the circluar gear. This produces the up/down left/right movement of the mirrors. They work together so both motors must be operational.
inside and front cover of actuator housing
AcuraTL2k4
Mar 8, 2005 09:28 AM
AnnapolisTL
Jan 14, 2005 08:09 AM
CLasified
Dec 21, 2001 02:08 AM
CLasified
Dec 5, 2001 03:38 PM
