Front right turn light acting weird
Old Aug 8, 2013 | 08:50 PM
Tuguldur's Avatar
Hey guys,
so I notice since yesterday or so when I give a turn signal to the right, the flashing frequency became very fast, much faster than when I give signal to turn left. I step outside, to see all right turn lights (front, mirror, back) are flashing, but at that high frequency. Plus I noticed only the front yellow light doesn't get as bright as the left light when it is signaling turn.
What is going on? Since all lights are working fine the fuses must be working. Is it a sign of something about my front signal bulb?
thanks,
Tuguldur
Old Aug 9, 2013 | 11:07 AM
Mr Marco's Avatar
Short or bad flasher relay.
Old Aug 10, 2013 | 09:40 PM
Tuguldur's Avatar
ok how do i fix it?
Old Aug 11, 2013 | 06:32 PM
Mr Marco's Avatar
Start with the bulb. Replace both sides and check for corrosion. If that is not the issue replace the relay under the dash. If that doesn't work you might have a short in the wire...it can be very difficult to find.
Old Aug 14, 2013 | 11:22 PM
Tuguldur's Avatar
Will try changing the bulb.
BTW yesterday evening for about 2 hours it actually worked fine suddenly. But today morning it was back with high frequency.
Old Aug 15, 2013 | 09:23 AM
Mr Marco's Avatar
Short. Those can be really hard to find. Could be any number of things.
I read once that a guy had a similar issue with his ride, turned out to be caused by a screw that was inadvertently left behind on the assemby line. The screw worked its way over to a wire and serveral years of vibraions caused the sharp edges to wear a hole in the wires insulation causing the issue.
That is rare. I would start wih the obvious areas, such as a crushed wire between the turn signal lens and body.
Old Sep 12, 2013 | 12:04 AM
Tuguldur's Avatar
since I have changed the front bulb it has been working fine, so far.
Feb 25, 2020 09:57 AM
Ny1718
Sep 11, 2015 09:21 AM
08 NBP TL
Sep 8, 2015 08:49 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
