CPE Intake + Hondata = ???
I had a K&N with a Hondata for a short time. No real economy benefit. The Hondata really only makes the RDX run slightly less rich under boost, so in order to "save" fuel over stock, you have to be driving reasonably aggressive still.
I believe the CP-E just uses a slightly larger MAF housing so the meter thinks it's metering slightly less air than it really is - so this might help a bit - but I'm sure all the other electronics will keep it an 14.7:1 under most conditions anyways.
There is simply not point to running rich under light throttle and cruising conditions. I've taken cars that were really bad on gas (Subaru Forester) and they ran a perfect 14.7:1 under idle, cruising and light throttle conditions.
On long trips, I have been able to get 23.5-24 mpg out of the RDX with the mods on. That's going 80mph on the highway. Just depends on how you drive it! Hope that helps!
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
