Check sh-awd, check vsa system, check emissions system
Old Mar 25, 2020 | 12:41 PM
BwaAnthony's Avatar
7th Gear
I have a 2007 Acura RDX, and I’ve been getting those three lights popping up on my dash and I have searched up the problem here and some possible solutions like removing and tightening the gas cap. So far I have changed the alternator and I’m still having this problem, ANY HELP ???
Old Mar 25, 2020 | 01:34 PM
Matt_ATX's Avatar
This can be caused by numerous issues, but it's always been a loose gas cap for me. I know the knock sensor going bad can cause it as well. Do you have a code reader?
-Matt
Old Mar 25, 2020 | 01:59 PM
BwaAnthony's Avatar
7th Gear
-Matt
REPLY: Yeah I’ve been doing that constantly to the gas cap and I check the reader and got the code P2647
Old Mar 25, 2020 | 02:43 PM
https://acurazine.com/forums/1g-rdx-...a-83-a-905932/
Old Mar 27, 2020 | 09:28 PM
acuratech481's Avatar
Needs an oil pressure switch.
Old Apr 2, 2020 | 02:51 PM
BwaAnthony's Avatar
7th Gear
I changed the vtec oil pressure
I HAVE CHANGED THE VTEC OIL PRESSURE SWITCH, and it still seems to be acting up, even though I did needed to change my oil pressure switch, the code came back up again, any other solutions???
Old Apr 2, 2020 | 07:15 PM
Could be many things. Would require more in depth diag. checking wires, checking voltages, checking ground, checking for a soft set connection either at the VTEC oil pressure switch or PCM, etc. Can't say this is something that will be diagnosed over the internet...
Also looking in the data list on a scanner may tell you some things if you know how to use one comparing inputs and outputs to see what is staying on or being commanded on when it shouldn't be. Could be a faulty PCM as well. On a side note, I doubt it's an oil level issue as that's usually the opposite code (stuck off).
All else fails, bring it to the dealership lol.
jim_blank
1G RDX (2007-2012)
May 18, 2018 06:40 AM
jfwalker2
4G TL Problems & Fixes
Oct 1, 2017 01:25 PM
natavio
1/2G MDX (2001-2013)
Jan 8, 2014 05:58 PM
civicracer1
Jan 9, 2013 04:55 PM
ajaj
1G RDX Problems & Fixes
Dec 13, 2012 09:15 PM
