Broken Engine Air Filter Housing Help
Old Feb 23, 2015 | 12:34 PM
Renegade's Avatar
Making it Happen
Hi All,
I went to change the engine air filter for my wife's 2010 RDX yesterday, and after removing 3 of the 4 screws that holds the top of the cover down, I noticed that for the 4th screw the plastic broke and the screw is stuck in, but when I reach around with my fingers I noticed there is a small gap that could allow air in (I temporarily duck taped this area). It appears that a prior owner couldnt get this 4th screw off, and tried to raise the cover enough to fit the air filter in, but raised it too high and snapped the plastic of that corner.
At this time, how urgent is it for me to replace the housing? Also, does anyone have a DIY on how to replace the top cover and the bottom pieces?
I believe I would need #1 and #2 as well as 4 bolts (#18) from here AIR INTAKE SYSTEM. Fits: Acura | Sons Acura
Can anyone confirm these are the right parts? Pics are below of what I'm talking about. Thanks!
Old Feb 23, 2015 | 07:54 PM
Tomtwtwtw's Avatar
So it's probably not critical as the gap you're referring to is still in front of the MAF (so no unmetered air will enter the system), and it's so small and isolated that only a small amount of dust may find its way in - nothing that can potentially damage engine components. Over the long haul your oil may get dirty just a bit faster, that's about it.
As for a DIY, I'm not aware of one but removing the battery will likely give you all the working room you need. Always an opportunity for you to make your own DIY for the rest of us!
Old Feb 23, 2015 | 08:16 PM
Renegade's Avatar
Making it Happen
Thanks Tom, I'm not very handy so no DIY for me
I am glad to know that the small gap where the plastic broke around that screw is not critical, as the air filter box is sitting pretty much flush except around that part. I will probably deal with it in another 30k miles when the engine air filter needs to be changed again. Thanks!
Old Feb 24, 2015 | 11:54 AM
Nachtsturm's Avatar
Good excuse to buy her a new cpe intake.
Old Feb 24, 2015 | 12:02 PM
Tomtwtwtw's Avatar
Not a bad idea! Probably a lot easier to install than a new airbox too.
rockyboy
Aug 4, 2024 10:35 AM
Abe_Froman
Sep 16, 2015 01:27 PM
Sep 14, 2015 10:09 PM
Aleax
Sep 9, 2015 08:04 PM
bymotion
Aug 31, 2015 05:00 PM
