Advice needed....transmission issue
Old Nov 25, 2019 | 05:16 PM
Sanman718's Avatar
I have a 2010 Acura RDX sh-AWD 2.3l turbo....just did a tune up (spark plugs, coils, knock sensor, oil change, etc...) and changed a couple front end parts (front sway bar, half shaft right front, tie rods outer left & right) to all of a sudden after about 10 miles of driving the transmission went bad. The shifter goes in all gears but no power to the pedal at all. When put in park a loud winning noise and car also rolls while in park....an ideas??? Is the transmission shot or is it possibly something else.... please help
Old Nov 26, 2019 | 08:14 AM
IgottaTLyousomething's Avatar
First thing I would do is check the transmission fluid to
determine if there is a coolant contamination.
Old Nov 26, 2019 | 10:16 AM
Tomtwtwtw's Avatar
And definitely check that half shaft.
Old Nov 26, 2019 | 02:58 PM
Tomtwtwtw's Avatar
Hey, delete some of your old messages so I can send you a response.
Old Nov 26, 2019 | 03:18 PM
Tomtwtwtw's Avatar
In case I forget to check back, I suspect the issue is your half-shaft was not properly installed. Either the mechanic didn't put the c-clip on the new axle, or didn't push it in all the way to where the it locked into place. Either way, the symptoms sound like the axle may have shifted too far out to where it's no longer connected to the transmission output. I'd recommend taking it back to the shop asap and don't start the car in anything other than neutral (really, don't start it at all unless you absolutely have to) to prevent any further damage.
Old Dec 2, 2019 | 03:43 PM
feralcomprehension's Avatar
Qualified Observer
This.
ericinbrooklyn
4G TL Problems & Fixes
20
Dec 14, 2024 04:29 PM
Mikezuy
1G RDX (2007-2012)
19
Oct 13, 2018 11:22 PM
RysTL04
Jun 13, 2016 05:38 PM
05tllover
Apr 10, 2016 08:25 PM
remingtonb27
1G RDX (2007-2012)
Sep 10, 2015 11:44 AM
