AC not working
AC not working
Hello I have a 2008 Acura RDX and the AC has stopped working. I replaced the AC compressor relay with the newer Mitsuba one and still have no cold air. The system is charged with the correct amount of AC. I want to know if the compressor is bad. I don't see the clutch engaging and spinning. I disconnected the harness to the compressor and found three wires. Only one wire from the harness, the green/red had 12V. I noted that the wire had 12V regardless of whether my AC was on/off. The other two wires in the harness were red/white and red/black and did not have 12V. Any help would be appreciated! Thanks.
There is a TSB for poor A/C performance and I believe its related to the clutch...ie - not engaging or not engaging properly. Obviously you're out of warranty but maybe since there is a TSB, they'll work with you on the price?
Michael Bower
Jun 30, 2018 12:31 PM
