35mm offset question
Old May 24, 2008 | 01:54 AM
jeffd1's Avatar
5th Gear
Hi
anybody know if a 35mm offset will be ok with a 20" rim tires are 245/45/20? any rubbing issues?
Anybody have a 35mm offset with 20" rims?
Old May 24, 2008 | 12:15 PM
wspy's Avatar
2008 Acura RDX
Those will be ok! They are the recomended plus size for the RDX.
Old May 24, 2008 | 12:26 PM
Patronus's Avatar
The rim width will make a difference. Stock is 7.5". If you stick with that, the outside of the wheel will be 10mm further toward the outside of the wheel well. If you have a wider wheel, you need to add half the difference from stock to that number.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
