2009 rdx
Old Nov 13, 2019 | 04:29 PM
golfhunting's Avatar
2009 rdx
Hi, I recently purchased 2009 RDX with about 75K miles. the car is fun to drive. The problem I'm experiencing is the car stall/turn off while in drive gear stopping at the signal light. This only happens when it's raining or the road is wet. Any help to diagnose and fix the issue is appreciated. Thanks.
Old Nov 14, 2019 | 11:07 AM
Tomtwtwtw's Avatar
First thing I would check is your engine air filter. It it's really old/dirty, that extra moisture in the air may be restricting it too much. I think that's not likely, but it takes 2 minutes to check. After that, and probably more likely, check your spark plug coils. If they are cracked slightly, water could be getting on them and causing issues. They sit right under your intercooler, and during a rainy day you'd definitely take in some water through the air inlet for the i/c.
annecrooks
1G RDX Problems & Fixes
Jul 1, 2017 07:02 PM
Blueeyeari
1G RDX (2007-2012)
Dec 2, 2015 09:37 PM
jwaters943
1G RDX (2007-2012)
18
Aug 1, 2007 12:05 PM
