2008 rdx warning: Service soon B12
Have beautiful one owner RDX very good condition.
B12 warning .. how much might this cost? At a dealership
I know this is probably a 200k service warning but wanted to know if I should take it to the dealership?
I just got the oil changed a month ago
Thank you
Thank you
CSmoney28
CODES PRICING GUIDE
- Code A: $49.95 Lube, Oil and Filter
- Code A1: $79.95 Lube, Oil, Filter and Tire Rotation
- Code B1: $149.95 Lube, Oil, Filter, Tire Rotation and Balance
- Code A12: $229.95 Lube, Oil, Filter, Tire Rotation, Engine Air, and Pollen Filter Replacement
- Code B12: $299.95 Lube, Oil, Filter, Tire Rotation, Tire Balance, Engine Air, and Pollen Filter Replacement
- Code A16: $179.95 Lube, Oil, Filter, Tire Rotation, Rear Differential Fluid Replacement
- Code B16: $249.95 Lube, Oil, Filter, Tire Rotation, Tire Balance, Rear Differential Fluid Replacement
- Code 1: $39.00 Tire Rotation Only
- Code 3: $104.95 Transmission Fluid Only Service
- Code 6: $99.95 Rear Differential Fluid Replacement
- Tire Patch: $42.92 Tire Repair-Install Patch
- Window Wipers: $29.95 Window Wiper Blade Inserts Only, Full Blade Replacement Additional
- ANY A/B SERVICE THAT HAS “4” LISTED-CALL FOR PRICING (timing belt/water pump replacement.)
The following 2 users liked this post by CSmoney28:
Jay Goodman (12-23-2020),
mrgold35 (12-23-2020)
mrgold35
A: Replace Engine Oil
B: Replace Engine Oil and Filter. Inspect various systems and components
1: Rotate Tires and check tire pressure and condition
2: Replace air cleaner element, check drive belt and replace dust and pollen filter
3: Replace transmission fluid and transfer fluid (if equipped)
4: Replace spark plugs, replace timing belt (if equipped), inspect water pump, and inspect value clearance)
5: Replace Engine Coolant
6: Replace rear differential fluid (if equipped)
Brake fluid every 3-4 years or during a brake job. Replace P/S fluid if never been changed or looks extremely dark and alignment as needed (I do alignment with new tires).
Sounds like the Maintenance reminder didn't get reset from the last oil change (MUST use 100% synthetic oil for the RDX). My oil change interval for my 08 RDX is usually starts around 4500 miles at the 15% M.I.D. reminder. You are only due for a B12 oil change change, filter replacement, and rotation/balance. That can be around +$175 depending on dealership. I purchase my own oil from Walmart for $26 compared to what Acura charges at around $50. I order my engine and cabin filter from Amazon or other on-line sources for $10-$25 and change them out myself in under 10 mins. I also have Discount Tires lifetime rotation/balance with my road hazard warranty I added to my RDX when I purchased my tires from them (about $30-$33 per tire and they can add to any tires).
That cuts my dealership B12 service down to around $30 at the dealership for my 08 RDX tech with +175,000 miles (trading my labor, time, and cheaper prices for theirs).
Jay Goodman (12-24-2020)
