2007 Acura RDX With Tech Pckage
Hello All,
I have an 07 Acura RDX with the tech package. I was wondering if anyone could tell me how to Reset the TPMS system since i cannot find the button anywhere on the dash?? My TPMS system light just came on and it shows 4 dashes for each tire on the display. It came on the other day since its been pretty cold in NY lately.
Thanks,
J74
Thanks,
J74
Are you getting a TPMS System Error on the little screen under your speedometer? This seems like it could be caused by a couple different components of the TPMS system, but is most commonly just one of the individual sensors failing. I've been having that same error intermittently for the past few months in my '11 RDX, and will be having my mechanic replace all four sensors next service to see if that resolves the issue.
Hello All,
Thanks,
J74
Thanks,
J74
https://autowise.com/how-to-reset-th...ight-yourself/
CSmoney28
First do you have stock wheels, tires, and sensors. Second have you used fix a flat, plugged, or patched the tires. Third are the tire pressures on all tires set the pressure recommended on the drivers door sill if stock wheels and tires. Fourth if aftermarket wheels and tires are the pressures set to the tire specifications on pressure. Let me know, thank you!
Tire pressure is all set properly to door placard.
No fix a flat and no aftermarket rims..
I was actually able to get a tpms scanner and reset the system, it did show the left front sensor battery low.So I guess I will have to replace that sensor eventually.
Thanks,
J74
Thanks,
Thanks,
J74
Thanks,
J74
Yes unfortunately that's the truth. Does anyone have recommendations on which ones are best to install ? I see lots of aftermarket ones out there to buy.
Thanks,
J74
Thanks,
J74
EasyLoveRDX (01-27-2021)
Honestly at 10+ years I'll just go OEM. They're only about $35 each. The ones in my previous car all died before 4 years.
https://www.oemacuraparts.com/oem-pa...ms-42753stka04
Joneill44
Sports Talk & Fantasy Leagues
1073
02-08-2021 01:12 PM
