1st service
Old Sep 28, 2010 | 12:08 AM
  #41
Mr Marco's Avatar
Originally Posted by XLR8R
CorrectionsAt 4 years and 72k miles, I've found the RDX to be the most trouble-free vehicle I've ever had and the easiest to perform DIY maintenance on.
For long service, your turbo needs both high quality oil and coolant. To protect your turbo:
1. Change your oil on schedule and use HTO-06 synthetic. Keep it topped up between changes, if needed.
2. Get some Honda Long Life Coolant Type 2 and keep the overflow tank between the Min and Max lines. (Important because after shutdown coolant is circulated through the turbo by convection.)
Only if temp is high
Other Fluids:
1. Change your transmission fluid every 40k miles. Use ATF-Z1. Check it once a month.
New fluid, see; https://acurazine.com/forums/1g-rdx-diy-faq-161/new-honda-atf-rear-diff-fluid-792655/
2. Change your other fluids per the MID^. You can also check Power Steering and Brake Reserviors very easily because they are both translucent with Min and Max lines.
There is nothing unique or intensive about RDX maintenance. For the DIYer, it is rather easy and pleasant.
If you don't DIY, you may find that a good independant Honda shop can keep your RDX checked and serviced for much less expense than a dealer. (..and give better advice too. It's clear this Service Advisor was establishing an early expectation of higher cost. The "private talk" was to avoid a public scene if the customer objects. It's all about managed expectations.)
Find another dealer.
Old Sep 29, 2010 | 09:50 AM
  #42
zozobar's Avatar
Originally Posted by discovermac
$135 for oil and filter change only? or did you include the "1" service = tire rotation? it's more like 195 in toronto after taxes for a complete A1...
yeah, oil change only. I do my own tires.
Old Sep 29, 2010 | 09:56 AM
  #43
russianDude's Avatar
maybe it included some checks ? thats insane. I just did my own oil because it was not easy to make an appointment with my dealer, took me 40min in my garage. I bought $30 5.25qt from autozone with Mobil1 oil filter, and also got $10 rebate cant beat that
Old Sep 29, 2010 | 10:11 AM
  #44
truelies's Avatar
$135 even charge more than BMW dealer. BTW, how to do tire rotation by your own? I think it's not so easy.
Old Sep 29, 2010 | 10:19 AM
  #45
truelies's Avatar
Great deal. How did you get $10 rebate?
Old Sep 29, 2010 | 11:01 AM
  #46
$30 for 5.25qt + Mobil1 filter is still on at autozone. there was also $10 gift card when purchase Mobil1, I dont think this rebate is still live.
Old Oct 1, 2010 | 10:42 AM
  #47
zozobar's Avatar
That's the crazy pricing in Canada. Also the RDX premium. I saw the price list for oil changes, $65 Reg Acura's, $89 MDX, $109 RDX + fees and stuff makes it $135. Somebody else pointed out $175 for a full A1 service in Toronto. What is the base price of the RDX in the US anyways, it was $41,500 CDN when I got mine last yr.
As for tire rotation, I just change to Winters with rims in Nov and back to the stock in May. So I only have 1 tire off at a time.
Old Oct 4, 2010 | 10:28 AM
  #48
XLR8R's Avatar
I'm not sure why you feel a "correction" is needed here. You would seem to be implying that coolant circulates by convection only during some condition other than normal: "only if the temp is high".
Directly from honda.com is this description of the RDX turbo cooling:
Water passages in the aluminum exhaust manifold help keep the temperature within the exhaust system at optimum levels for both the turbocharger and catalytic converter. When the engine is shut off, coolant continues to circulate within the turbo housing due to thermal convection, helping prevent long-term heat-related damage to the turbocharger bearings.
This description clearly applies across the operating temperature range of the coolant -- controlled at a median 93 celcius by the thermostat.
Old Oct 4, 2010 | 01:39 PM
  #49
black label's Avatar
Trolling Canuckistan
My BMW 528i usually change oil each 15000 miles with full synthetic. I don't like RDX that needs to do it each 4000 miles, that not only means more expensive, but also a lot of time (to dealer or diy)
BMW's service intrervals are based on the fact that BMW pays for the service for the first 4 years or 50,000 miles not on what is best for the car. If that lack of service causes issues in the 50K plus range, they could care less, they are no longer footing the bill.
Old Oct 16, 2010 | 06:54 PM
  #50
Pro4Ski's Avatar
2010 SH AWD RDX
Just curious..I have a 2010 RDX and have 3300 miles on it. My understanding is the onboard computer will let me know when to get the oil change. Is this accurate?
Old Oct 16, 2010 | 09:43 PM
  #51
Piggy791's Avatar
5th Gear
Yup, at 15% oil life remaining, it'll pop a reminder on the MID each time you start the car saying, "Service Due Soon". It will also tell you which service code is due. Most likely the "A1" service will be first which is an oil change and tire rotation. At 5% oil life it will change the MID to "Service Due Now".
If I remember correctly, the owners manual saysthe MID will count the number of miles driven at 0% oil life that the dealer can check . . . Not sure if it has ever been used against anyone.
Old Oct 17, 2010 | 05:17 PM
  #52
Pro4Ski's Avatar
2010 SH AWD RDX
Thanks!!
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
