Any Acura techs in the house?
Can someone tell me (or check with a friend who works at Acura or has the service manual) where the 'S' line/wire from the alternator on a '95-'05 NSX goes to? If someone could take a pic/scan the page from the service manual that would be even better.
Service manual is available online.
The only way I'd be able to take a picture is of it on my computer screen.
Google 'acura tl service manual' and then click on the first link. On the left side of the screen there will be a link to the NSX manual.
I'll do my best to identify what you're talking about. First, there is no 'S' (signal) line/wire on the alternator, that would relate to the starter. On the back of the alternator there is a green connector that goes to the main wire harness which ends up at the PCM. The other wire on top of the alternator which should have a black rubber boot is your 'B+' or Battery positive wire, which goes to the battery.
Hope that helps
Thanks for the reply. I have seen that manual already but it is for a '91. Are you saying that the alterator connections are exactly the same as the later models?
I'm not a tech, I Manage the Service Department at Acura of Lynnwood and I personally own an NSX. If I don't know the answer to your question(s), I have some of the BEST NSX techs in the country that work for me and I'll be able to get you the answer.
Hope that helps
Hope that helps
Evil Teo
3G MDX (2014-2020)
14
Aug 16, 2020 04:29 AM
, if there are any Acura techs with NSX knowledge in the house, they'd be in the NSX section. Moving this there...
