Wheel Spacer Pics
Wheel Spacer Pics
Hey CLer's,
Do you have any pics of 17/18/19 rims on our CL's with wheel spacers (5-15mm)? I just bought H&R 5mm fronts and 10mm rears (with extended studs) and want to see how flush spacers make the wheels on our cars. I did a search for it, but the pics are years old and won't display. I have 225/40/18, KYB AGX and neuspeed sport springs 1.75 F/ 1.5 R drop. I think user xxx had a similar setup. Also, Cocoa's car looks like he has spacers. Thanks in advance!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If I recall correctly, cocoa's car doesn't have spacers, fliplyricist1 went through a few sets of spacers, search for his threads
Old School Ridin Clean
where is....
i've heard different things, but its usually recommended that you get extended lugs if you run spacers.
spacers push the wheels out from rubbing or for brake clearance. it does also widen the wheel stance, but it also has the same properties as going with wheels that have lower offsets, so instead of throwing 10mm spacers on the 17x7 +55, you can get wheels that are 17x7 +45 for the same stance.
![Naughty](https://acurazine.com/forums/images/smilies/naughty.gif)
![what](https://acurazine.com/forums/images/smilies/what.gif)
(Mid-Atlantic)
(Mid-Atlantic)
i like acura
most legit quality spacers above 5mm come with the extended studs on them. kinda like an adapter.
or you could buy extended ones and have them pressed on.
extended studs are hella cheap. just hard to put on.
1 Post
I broke a stud one time and put the new one in by hand. It was kind of a bitch though basically tapped it in and then used the lug to pull it the rest of the way.... it's been a year now so far so good.
merc009
10-03-2015 12:59 AM
mtl_ilx
09-03-2015 09:48 AM
