Struts and Camber
Struts and Camber
First, If the CL were to have a failing strut on one side, would that side sag or appear lower than the other side? I wasn't sure if the ride height depends on struts or solely on the springs.
Second, I have a problem with camber in the rear. But the side that appears lower (see first question) is off more in the camber spec. So, could a failing strut contribute to that camber spec? In other words, since the car is sagging on that one side, is that pushing the camber out of spec more?
Eibach Pro-Kit installed 1 1/2 years.
could be, if you push down on your car, it should bounce up once and stop, if it keeps bouncing a little (or a lot), get some suspension work man!
it could, possibly, throw of camber, but dont quote me on that one.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
