rough suspension??please help
Old Jun 13, 2008 | 09:06 AM
YL Al's Avatar
shes rough!!lol
new struts,new drive shafts,new balljoints,new tires(BUT THEY ALL FROM DIFFERENT COMPANIES??) what could be making this problem? im all stock suspension too
Old Jun 13, 2008 | 09:13 AM
YL Al's Avatar
oh and can it be bad springs causing this?
Old Jun 13, 2008 | 09:57 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Are your wheels road force balanced? How is it rough? Is it bumpy? Stiff? What?
Old Jun 13, 2008 | 01:07 PM
YL Al's Avatar
the wheels are not balanced as far as i know,its severly bumpy and harsh ...but how can wheel balance help the shock system?
Old Jun 13, 2008 | 01:13 PM
CH46ESeaKnight's Avatar
I can't imagine anyone would have mounted your new tires and not balaced them! If they are not balanced then I'd bet thats your problem. 100%.
Old Jun 13, 2008 | 01:28 PM
(Mid-Atlantic)
Balancing the wheel to the rim ensures a smoother ride, also allignment may be off that could def happen from changing the balljoints and axles
Old Jun 13, 2008 | 01:34 PM
YL Al's Avatar
ok ill start with a balance
whats a good deal $$$
Old Jun 13, 2008 | 01:37 PM
Who put the tires on? I'm sure they would have balanced them! Go look at your rims inside and out and look for new weights that might have been added. Balancing 4 tires can be a bit pricey, especially if they don't need it.
Old Jun 13, 2008 | 01:41 PM
(Mid-Atlantic)
Road force balance is the way to go
Old Jun 13, 2008 | 01:53 PM
Wow, I never head of that before. Just did some reading over on the Cadillac forums and they are swearing by it. I guess when I get some new tires I'll have to get that done. Thanks Man.
Old Jun 13, 2008 | 02:05 PM
YL Al's Avatar
it was a tire shop that put them on,they had no equipment for balancing!!
Old Jun 13, 2008 | 02:17 PM
(Mid-Atlantic)
Old Jun 13, 2008 | 02:29 PM
jfkhan's Avatar
Jhatt from Ludhianna
IMPOSSIBLE...............
A tire shop with no balancing equipment...............funny....was the location in mexico................:rolf:
JFK
Old Jun 13, 2008 | 02:30 PM
YL Al's Avatar
lol but how can a bad balance cause a rough suspension at ANY SPEED someone please explain?
Old Jun 13, 2008 | 02:45 PM
YL Al's Avatar
and remember when my lower ball joint fell off? it took a considerable amount of metal from the rim through scracthing it,no balance was done after that as well
Old Jun 13, 2008 | 03:59 PM
AznX TL's Avatar
where is....
it might be your tires, mine was rough when i first bought the car at any speed over 40mph. but as soon as i got tires it was smooth as a baby's ass.
Old Jun 13, 2008 | 04:06 PM
(Mid-Atlantic)
Bent rim?
Old Jun 13, 2008 | 04:10 PM
YL Al's Avatar
no the rim is not bent...beat up though,scratched from side
but im talking about LOW Speed bumpy ride
Old Jun 13, 2008 | 09:47 PM
tron's Avatar
damn you post a lot. It seems like you have a new problem everyday
Old Jun 14, 2008 | 07:17 AM
YL Al's Avatar
see the thing is i bought my cl from an auction,they had no test drives,after buying it i found out that the whole suspension and steering system is destroyed,ie rusted,this lead me to put the new parts in (1st post) and the car has improved dramatically but it still has that unstable and bumpy ride to it..maybe due to the pssngr side accident from previous owner.i didnt expect to waste so much money on the suspension of car
Old Jun 14, 2008 | 09:18 AM
sayfulhaqq's Avatar
wow man , just get an alignment and get your tires balanced. if needed, rotate your tires. After that, your car should be fine. By the way I brought my car from the auction and I was able to test drive it and I brought a mechanic who fully inspected the car before I dropped the cash on it. Do extensive research before you buy a car , especially on a car at an auction, you can never be too careful.
Old Jun 14, 2008 | 09:25 AM
YL Al's Avatar
how much is it to get the balance? ill DIY the tires though
Old Jun 14, 2008 | 12:25 PM
(Mid-Atlantic)
Shouldn't be too bad, any larger tire shop should be alright. Shouldn't be more than say $100
Balancing a tire is more than air, they balance the wheel and tire to each other. Just let a shop do it
Old Jun 14, 2008 | 02:27 PM
YL Al's Avatar
appreciate the info guys
Old Jun 14, 2008 | 04:47 PM
Mr_Xclusive808's Avatar
Where is it bumpy? Front & back? If after you do the balancing & rotation check your control arms for cracks or and signs of being bent. Or if only the front check your Upper control arm & anchor bolts.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
baelim
May 10, 2018 09:53 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
