everybody with Koni yellows & camber kits!!!!
yo where did u guys get your Koni yellows from... how much??? do accords fit?? would it be cheaper to get acoords??? i have a 3.0 so let me know what i got to get!!! i keep getting stressed to go lower so here i go!!!! also where can i get cheap camber kits?? Thanks pimps!!!
AWD Torque Monster
i got my koni yellows for $515 shipped from import horizon. they are a good business. i also got the eibach camber kit which was like $150 shipped, then i had to order the tool to adj it which was another $40 shipped. you will definitely need a camber kit though. i got prokits and koni yellows with the front on the elower perch so im talking from experience. i have a 2.2 also so im sure the 3.0 will be sittin a little lower.
AWD Torque Monster
Originally posted by r0dxx
VXCL, Im just thinking you paid 515 for the shocks and probally 200 for the prokit. You were like 85 dollars away from TEIN's!! ahah
VXCL could you post pictures of your car? I would love to see how that drop looks. I am thinking about lowering my car and I am debating what would be the best setup for me
sorry to jack the thread but:
The Teins come with struts/shocks AND springs? Cuz I coulda gotten Teins....
$500 on struts + $250 on Eibach springs
Man I wish I knew more about suspension before i bought mine
AWD Torque Monster
Originally posted by lomeli3.0CL
i heard the ride quality on the pro kit and aftermarket struts is alot better then the teins anyways..
pics of drop
prokits/koni yellows
front 2.25" (lower perch)
rear 2" (standard perch)
Thanks for posting those pics VXCL the drop looks great! I heard that the koni struts would lower the car more but I dont understood how, I always thought that the firmness of the struts were adjustable not the height. I assume they must have the same kinda perch as coilovers or is it a different setup (I cant tell from the pictures of the struts)? If the height adjust how hard is this to do? Thanks for your help.
AWD Torque Monster
there is a lower perch on the shock to lower the car more. like coilover but its fixed in 3 spots. it will lower ur car another .25-.5". you can only adj it with the shock off the car.
AWD Torque Monster
I heard that the Koni require some cutting and modification to replace the stock strut?? is this true?? i just want to be able to slap them in without all the hassle.... that is why i am concidering kyb's......
direct bolt on for me. if ur talking about cutting the bump stops and enlarging the hole in the dust cover that takes 2 secs and is by far easier then getting the rear shocks off or compressing the front shocks. if i was you i would take the shocks off ur car and bring them to a shop to be compressed and taken apart. use a $3 spring compressor off ebay to install the new springs becuase they will need barley any compressing if at all.
AWD Torque Monster
how much did you have to cut the bump stops???what did you cut it with??? i have access to a spring compressor and air tools so it wont be that bad.... did you install your camber kits as well??
the camber kit is not installed yet becuase im wainting for my rims to get an alignment. heres pics of it. very basy, easy install, you just dial in the camber by turning the metal sleave with the special tool. new poly bushings also! its the eibach camber kit (made by spc)
the camber kit was like $140 and the tool was another $30
I just got my koni, and all I received is 4 shocks, and those nuts, washers, white washers, and stuffness adjustment nob. I am installing this right now, and wondering if I need to the get dust cover off the stock, and replace to the koni's?? But that's not possible tho because the washer on the top of the stock shocks was like welded on there, I couldnt get the dust cover off there.
also what's the bump stops look like?? I know, I am a noobie. Sorry for all those questions, man. Please advise.
Jeff
Jeff
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-28-2015 05:43 PM
