4x114.3 to 4x100..
4x114.3 to 4x100..
so i found a wiked deal that i couldnt pass up. I went and got wheels that were 4x100, is it possible to go down from our lug pattern to 4x100.. i was looking at cheap converstions on ebay.. http://cgi.ebay.com/ebaymotors/25mm-...Q5fAccessories
please i need help asap! or ican just sell em for more
Well obviously you found adapters, so i suppose its possible. I've never seen them on a CL before, you could be the first! What kind of wheels did u get a deal on?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Yep those are the adapters that you need, those are almost exactly like my 5 lug conversion that I had made several years ago, same design.
Be aware that you are spacing out your rims from the hubs which could affect your fenders
There only Konig Britelites, there in silver and black 17".. but they are in absolute mint condition.. I know that the spacers are 25mm but i cant find any that are smaller. I need to do some more research 8 mm is the most we should go right.
(Mid-Atlantic)
(Mid-Atlantic)
You're not understanding, the whole spacer is 25 mm (1 inch), in order to still use your studs you can only go 7-8 mm. But it looks like the inner holes for the stock studs isn't that far out, you should be ok.
You shouldn't need extended studs for this setup, because there are new studs on the spacer
could you send some pictures cause im really worried about doing this, especially now that i know there is going to be stress on my stock suspension, joints etc.... and eventually on my new suspension.
(Mid-Atlantic)
(Mid-Atlantic)
You're dropping on 17's correct?
(Mid-Atlantic)
(Mid-Atlantic)
215 isn't that wide, it really would depend on how far you plan to drop it, but 17's are usually 7, or 7.5" wide, so you have some room to work with in the fenders with the spacers. Best advice I could give you is to get coilovers if you're going to drop, that way if you're going to rub your fenders, you can raise the height
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
215 isn't that wide, it really would depend on how far you plan to drop it, but 17's are usually 7, or 7.5" wide, so you have some room to work with in the fenders with the spacers. Best advice I could give you is to get coilovers if you're going to drop, that way if you're going to rub your fenders, you can raise the height ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
HaPPy jU1cE
09-14-2008 06:08 PM
htown
11-21-2007 02:03 PM
htown
09-23-2007 01:41 PM
htown
05-03-2007 02:28 PM
