windshield spray problem
8th Gear
okay so the passenger side windshield sprayer doesnt work on my 97 CL.. Anyone knwo the problem? Is it just a fuse or is something to do with the sprayer?
Bagel Bomber
yeah check the hose. mine looked like it was eaten though by some bug or something and was causing it to spill all over the engine bay.
Does the pump make noise?
ehhhh, that must have been a nice surprise.
Bagel Bomber
yeah, check hose and clear the nozzles on the other one with a sewing pin or something. Also they are pretty easy to remove, you might be able to blow the nozzles clear.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Pin or needle will work to unclog
8th Gear
Ok so anyways i looked at the hoses the other day and seemed fine... but yeah the sprayer is now working, weird cause i didnt even do anythign didnt do the pin needle thing either i just tried it and it magically worked again... But i swear a couple days ago that one side was not working
my passenger side was just sputtering. driver's side was normal. I tried a pin and all that did was make the washer shoot over the car on the driver's side (alignment forthcoming). So I used compressed air. The washer reservoir is in front of the right front tire - get on your back to get an angle. Disconnect the tube and put a bucket under there to catch the fluid. It may take a while to drain esp if you just filled it. then shoot some comp air in the end of the hose and that will clear the nozzles.
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
rboller
09-23-2015 02:49 PM
