WEAK headlights!
WEAK headlights!
Hey,
I have a 1999 acura 3.0 cl and my headlights are ridiculously weak.
when I use them, it's almost as if I have no headlights on, and the high beams look like normal lights to me.
I just recently bought it in June, so I was wondering if this is with everyone's cars.
If I replace them will it be brighter?
Is there any way to install fog lights onto the car as well?
Thanks!
Thanks!
CL in lawnmower status
there is OEM foglights or universal ones, OEM are pretty impossible to find, and universal ones tend to look like crap IMO
i had the same problem with the headlights, i could barely see the light on the road when i had them on, that's why i switched to HID's and they're much better, and not really that expensive
U could have a parasitic draw somewhere in your circuit. U have to check the voltage at your headlight. I think it should be 12v, if its lower, something is drawing voltage somewhere.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Get some silverstar ultras or an hid kit
1st Gen CL Noob
I hated the light output from the stock headlights, and replacing the OEM bulbs with Silverstars were marginally better...but they sucked because they would burn out within a year, and then I'd have to replace again....reliability-wise they blow
I tried another brand (Litech) which had better/bright outputs but would also burn-out the same as the Silverstars....
Now I'm happy I didn't go the route that everyone else went with those various HID-kits, but did the HIR to 9006 bulb mods which turned out great!
I definitely get near HID output but without glaring any oncoming traffic and best thing is, I don't need to worry about any ballast burning out
AmplifiedDetails
09-24-2015 02:55 PM
