Trans mount question?
I searched didn't see anything on replacing a trans mount? Can u jus take the tranny mount out itself w/ out undoing any of the motor mounts? It seems u need clearance to get it over the stud and out?
Completely assuming it's a 2.x since you have not specified. You can simply undo the trans mount by itself if it's the one towards the pass side of the car. Just need to put a jack under the trans to support it while you do so. Obviously use common sense and use some wood so you don't pierce / crack the trans casing.
My bad yea it's 2.3 and it's a clearance issue.. The mount has two bolts that bolt onto a bracket and the bracket to trans stud... But the place where the mount bolts to the car overhangs the mount so when u unbolt the mount there not enuff between the over hang and trans to get mount over the stud? And the trans dosent drop enuff for clearance? I think I jus figured out a way by lookin at a exploded diagram of the mounts thoe? Im gonna give it a look tomm.I'm thinking if I take the threw bolt out and the nut on the stud maybe I can get under the bracket enuff to he the two bottom bolts out w/ out having to remove the braket over the stud? But then Ima have a prob gettin the two bottom bolts torqued to spec! Idk we'll see??Thanks for responding man!! I jus wanted to see if anyone had some "tricks of the trade" info for me!
DiamondJoeQuimby
09-10-2015 11:40 AM
