Ticking from Tensioner Pulley
Old Jun 7, 2009 | 09:21 AM
Acura99&06's Avatar
3rd Gear
I have a 99 CL that appears to be ticking from the tensioner pulley on the serpentine belt. It only ticks when the car is at idle and goes away when the engine revs up. The belt is new just had timing belt replaced a few months back. Any help on removing or similiar experiences would be appreciated.
Old Jun 7, 2009 | 11:12 AM
TexasHonda's Avatar
Tensioner pulley should have a large nut or bolt retaining the pulley. First slack and remove accessory belt. Remove retaining nut/bolt and remove tensioner. Then either remove the pulley bearing grease cap (small screwdriver w/ minimum prying, and more sliding around cap) and clean/repack, or replace tensioner. Reinstall tensioner and belt.
good luck
Old Jun 7, 2009 | 11:56 AM
Acura99&06's Avatar
3rd Gear
Thanks TexasHonda, I tried an experiment while the car was running, I placed a wrench on the nut of the tensioner and applied pressure on and away from the tensioner and the ticking/clicking noise still remained. Not so sure its the tensioner any more. The odd part is that the noise quickly disappears when the engine is reved up.
Thanks, Acura 99CL&MDX06
Old Jun 12, 2009 | 06:36 PM
TexasHonda's Avatar
Noises in this area of car can be very difficult to pinpoint. Sometimes a tube can be used as a stethoscope to pinpoint the source. Be careful not to get caught in accessory belt.
good luck
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
TL14
Sep 24, 2015 04:37 PM
iCrap
Sep 11, 2015 06:21 PM
